Author Topic: Wiring Harness for CB750K2 - OEM versus NOS?? Any difference??  (Read 2428 times)
Hi all,
Now that I have the engine almost complete Im looking at a new wiring harness for my CB750K2. Ive seen a pattern part (OEM) one at David Silver Spares for the K2 but does anyone have experience with this pattern part? Is it the same colours/connectors as the original?? I have the part no. for a 1975 wiring harness but not for the 1972 750 - is there any real difference??
Thanks as always,
Andy in Boston
Offline ride_a_honda
Re: Wiring Harness for CB750K2 - OEM versus NOS?? Any difference??
« Reply #1 on: May 01, 2005, 10:05:29 PM »
Hello Andy, I purchased the OEM Harness from David Silvers Spares a few months back. It is still in the package it came in as I'm not quite at the Electrical Re-assembly stage yet. Let me pull it out and compare it to my original harness. I can take a couple of digital pics if it would help you. Personally, after a very quick look and a good conversation with a buddy with a Norton, (he did this to his new harness) I'm going to solder all the connectors so that there is no possibility of a loose connection.
For your info, my bike is a CB750K3 but the build date is November 1972 and it has items from both the K2....AND...K3 models.....go figure. Now, I've owned this bike since 1980, and it was almost completely original then. (had a Kerker 4 into 1) I've since painted it a couple of times and it is completely dis-assembled right now. (OK....swingarm and rear wheel are installed....but that's it)
Give me a couple of days to sort things out and I'll get back to you.
Lou in Cold Lake, Alberta, Canada.
1973 CB750K2 (build date 09/72) S/N 2063462
Currently being restored, still.......!
So much work left to do..................so little time!
After a short hiatus...I'm back in restoration mode!
« Reply #2 on: May 02, 2005, 05:35:13 AM »
Thanks Lou that was the exactly the kind of feedback I was looking for! Im doing something similar to you in terms of a rebuild and have brand new switches (K3 type) for the right hand side - looks really good. The K2 was the first bike I bought when I came to the States in 1999 and after some engine problems lay dormant for a couple of years and a friend of mine was using the electrics for parts so the harness got chopped along the way which is why Im looking to make all wiring new again! Look forward to your thoughts on the OEM harness. And good luck with your own rebuild!
Cheers
Andy
« Reply #3 on: May 02, 2005, 08:58:37 PM »
Hello Andy,
so I went out to my garage this evening and took a few photos of the Harness for you. I'll post a couple here and you can e-mail me for the rest. I have 8 or 9 photos of both the new harness and my original one.
Point of interest, the wrapping seems to be quite light, I suspect that I'll spend some time and wrap it with "vulcanizing" tape. This will make it more resilient to water ingress......in the event you end up driving in the rain. As well, all the connectors are crimped. They appear to be loosely crinped.....so over beers and a chat with my Norton buddy, I've decided that I'm going to solder each connector. This should prevent any loss of electrons, and we all know that these old CB's need every little electron that the alternator produces. ;D
So, here are a couple of photos.
Cheers, Lou.
« Last Edit: June 25, 2007, 07:11:49 AM by Glenn Stauffer »
« Reply #4 on: May 03, 2005, 06:43:36 AM »
That looks OK.....what is the cost?
« Reply #5 on: May 03, 2005, 07:29:31 AM »
Thanks Lou for the pics -Ill email you for the rest. Mike the cost is 55 pounds from David Silver Spares,UK for the K2 harness.
Cheers
Andy
« Reply #6 on: May 03, 2005, 03:13:06 PM »
Hello Andy,
got your e-mail today and attempted to send you the photos via a "reply", but my e-mail was turned back as "The return address was refused." from your e-mail provider.
I have 10 photos for you, if you enter my e-mail address into you ISP's list, I should be able to send it again. Thanks.
(or possibly provide a different address)
Lou.
« Reply #7 on: May 04, 2005, 06:36:19 AM »
Oops sorry Lou not sure what happend there....try sending to andy69t@yahoo.com...there should be no problems with this address. Thanks again,
Andy
« Reply #8 on: May 04, 2005, 10:21:05 PM »
Hello Andy, sorry for the delay. Have company over and just getting to my e-mail now.
Let me take care of these photos right now.
Cheers.
Lou.
