Tom - STOP! - hold everything......
This is one of the problems that was created when this new version of the site was created, the OLD threads werent archived and copied across.
THIS is the answer. The problem is actually VERY simple, and eventually occurs on a LOT of 550s.
Its NOT the needle seat or needle, ok? And the dead giveaway is that its only from ONE carb, they would all have worn roughly at the same rate if at all, and they dont wear that much.....
The answer is actually ABOVE the needle seat.Remove the float in that carb by pushing the little pin it floats on out of the two alloy columns with a matchstick or something soft. Inspect it carefully......
And what you'll see is a number of rings on the little pin. What has happened is that the float has worn the centre section of the pin, ok? THEN as time passes the ENDS of the pin fret veeeeeeeery slowly in the two alloy columns, and the ends wear, and float back and forth a little...which means that as it moves thru to one side or the other (it cant go all the way out dont worry) the portion of worn pin from INSIDE one of the mounting posts peeks out into the centre between the two posts....and although worn it has worn at a different rate to the centre part where the float rubs....and so theres a "step" or "shoulder" for one end of the float pivot section to hang up on! If you could get it under a VERY powerful microscope the pin would now be shaped faintly like a dumbell.
Ok so far? Now, you can get new pins...but you have to buy as part of a float kit, VERY expensive but you only need ONE. And you get a new float at the same time lol. Now, the only issue is that as the fretting in the mounting posts occurs, the ALLOY wears as well as the steel pin, so its still free to move...see the problem now? itll still move a round a little. So positively locate it with a tiny bit of Loctite - I mean the cyanolatic glue not the studlock lol JUST a little, so that the pin doesnt move again. Believe me, theres NO other reason you should ever have to move the pin again if you fit the new float at the same time.....
Re-fit carbs, switch on, ride and enjoy.
Happens on a LOT of high-mileage 550s, same as the breaking countershaft sliding third gear. Oh,has noone mentioned THAT yet?
![Huh ???](http://forums.sohc4.net/Smileys/default/huh.gif)
Phylo
