Author Topic: CB450 hard to kick over  (Read 4161 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: April 16, 2011, 06:05:19 PM »
I've amended this post, it kicks over but with a lot of resistance. Any ideas?
Engine turns over with starter, but the kick lever won't budge. If I put pressure on the lever at the same time as running the electric start it will move, but not on it's own.
Is there a some kind of kick failure engagement issue with these bikes?
« Last Edit: April 17, 2011, 05:38:16 PM by B.O.X.N.I.F.E. »
1974 CB550
Forever West
  • The Stumped
Re: CB450 kick start lever won't engage
« Reply #1 on: April 16, 2011, 07:54:32 PM »
scratch that... it kicks over, but with a lot of resistance. are the 450's just monsters to kick over compared to my 550?
bastard still won't start, has fuel & correctly timed spark  >:(
1974 CB550
Forever West
Offline hoodellyhoo
  • CB350F
« Reply #2 on: April 17, 2011, 07:36:56 AM »
I've kicked over a few 450 motors in parts bikes and found it no harder than on my 350.
Offline grcamna2
Re: CB450 hard to kick over
« Reply #3 on: June 11, 2011, 07:40:58 PM »
  The kickstart lever is short for what it has to do.
75' CB400F/'bunch o' parts'
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: June 11, 2011, 09:40:37 PM »
A 450 is not hard to kick, you may have a problem with the gear.  You mentioned spark and fuel but what about compression? and are the carbs clean?  Also, a 450 will not start unless the choke is completely closed, it is one of the more cold-blooded Hondas...Larry
Offline grcamna2
« Reply #5 on: June 12, 2011, 05:12:24 AM »
  Try fully cleaning the points and static timing it,valve adj.,and good plugs,etc. &
then do what the man on the last post said...work w/ the choke fully closed...
maybe try a small hair open,then closed again, working the starter and while you
are doing that, try your best to keep the throttle butterflys just about closed also.
What I have described creates the maximum vacuum draw through the carbs. while
allowing just enough air in to start it. Play with the"closed throttle idea" for a bit
& if the plugs get wet, check your floats & float needles and make sure your carbs
are all set to spec, i.e. floats not filled w/ fuel,float height correct,float needles sealing
well,etc. & OH YEAH...MAKE SURE that you synchronize both of your throttle cables....
in other words get both throttle butterflys opening & closing at exactly the same time !
Work w/ the throttle cable adjusters on top of ea. carb.
        ALL the Best,
        Bill
Offline tbpmusic
« Reply #6 on: June 12, 2011, 07:41:07 AM »
450 isn't all that hard to kick over, though it is harder than a 350 (it's a manlier engine).
Main problem with a 450 is that the kicker doesn't really even engage till you're almost halfway through the kick stroke.
That said, sounds like you have a problem with the kick shaft or its engaging mechanism.
Sadly, this stuff is mainly all inside the crankcases, require engine removal and case splitting to replace.
A small part of the mechanism can be accessed by pulling the oil filter and oil pump/clutch, but it's mostly inside the cases.
Bill Lane
Offline grcamna2
« Reply #7 on: June 16, 2011, 05:01:10 AM »
Have you got it starting nicely yet ?
