If you have PD carbs, the max float setting is 14.5mm. 22mm setting is way too high and probably feeding raw gas into the engine from overflow. It would explain the sooty plugs.
Sorry LLoyd, but would 22mm float setting on a PD carb mean that hardly any fuel would get into the bowl? My understanding is that float hight is measured between the carb flange and the lower edge of the float. So a higher distance means that the floats close the valve earlier allowing less fuel into the bowl.
You are right, Fritz. I claim mental inversion on my part. (I wonder if that's part of my increasing dyslexia w/age?)
Sorry for that error.
Still, 22mm is just way wrong for the PD carbs and needs to be corrected.
Could be that whoever put the pods on also meddled with the jetting. The carbs will have to be checked for orifice size marks and/or drilling (so the numbers won't match the actual hole size of the jet).
Could also be that non-Honda parts were used in a prior rebuild. Check the numbers on the slide needles.
Oh, and look where the slide needle enters the body of the carb. There are supposed to be calibrated orifices for the needle to enter. If those were left out or drilled too big, way too much fuel would get sucked in.
Another issue: the jets seem to be stuck to the emulsifier tubes. The guy at Jets R Us says they should separate. Would soaking in oil do the trick? Vinegar might dissolve mineral deposits that are sticking them together, but would also attack the brass.
Try a 50% mix of acetone and Automatic Transmission fluid. This won't dissolve brass, and is superior to most penetrating fluids.
The X46a the chart referred to, is from the Honda shop manual. But, I don't think the X was ever stamped on the carbs. I think that the Honda tech writer used advanced engineering info, and publication schedules didn't allow for corrections or final proofreading, before delivery of both machine and documentation to customers.
