You got pods huh? What brand? The cheap ones are very hard to tune right. The k&n work better but 120s might not be large enough. Although, at 50 in 5th, you are also not in the powerband at all. Ease it to 75 and see if things are better, you will at least be in the start of your main powerband then, and running a bit more in the mains and if you still have the issue, good chance your mains are too small. You can kinda test this by partially closing the choke a bit to see if it will help.
