Author Topic: Lowest profile 19" front tire  (Read 665 times)
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« on: April 20, 2011, 10:27:30 AM »
First off, this has nothing to do with the Honda I'm working on, but on a BMW R100. Since they essentially run the same stock size tires (18 rear, 19 front) I thought I'd ask here.
I'm looking for the lowest profile 19" front tire you guys can think of. A friend of mine made a custom hugging front fneder and I was running an Avon Venom 100/90 on the font. Well after about 50 miles I started hearing this scarping sound only to discover that tire had expanded and the machine head screw inside the fender had cut a nice groove into the tire:
I reworked the fender mounts to be as flush possible on the inside but I'm still getting some rubbing with an Avon Roadrunner 100/90 19 I had.
Anyone know of a lower profile 19" front tore I might look at?
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Re: Lowest profile 19" front tire
« Reply #1 on: April 20, 2011, 08:42:31 PM »
 Slot the fender mount holes tomove fender up..and same with the brace..
Offline wookie
  • I would get up if i knew i fell
« Reply #2 on: April 20, 2011, 10:30:38 PM »
swellguy,
Ive got a 90/90/19 bridgestone spitfire with 80-90% tread if you want.   Free
