I'm working on getting a 750 F3 back on the road, and experienced a brake failure a couple weeks ago that was discussed in another thread. The rear brake ended up slowly seizing on me, which I attributed to a bad caliper piston...the piston was pitted badly. I picked up a new piston and new seal, and started working on the caliper. When I reassembled the caliper and began to bleed the line I noticed brake fluid dripping from the bottom of the master cylinder.
I removed the master cylinder, and something extra-ordinary happened...the piston shot out the bottom of the MC as soon as it was removed...that clip was either left hanging or installed improperly and came loose. The piston itself will definitely need to be replaced; the shaft of the piston was actually breaking apart right above the rubber seal on the lower end
...should have taken a pic. At first I thought the lack of the clip allowed the washer to sit at an angle and wear into the shaft...but thinking back to how it is assembled, I'm not sure if that's correct or not.
I cleaned out the bore, and reassembled the MC. The piston was not frozen (obviously, since it just fell out), and I manually actuated that plastic diaphragm(?) inside the MC with the piston to confirm it functioned, which it does.
The MC is still leaking though, which I assume is why I am having a heck of a time bleeding the system and getting the brake to work. Used a syringe to backfill the line, draw out air, and still nothing. This is odd to me since the brakes actually worked prior to the failure.
Could the heat have destroyed my MC? Or can I get away with getting it to work with a rebuild kit? The leak doesn't seem bad...after 10 or so pumps of the brake I get a few drops from the bottom of the MC.
Can someone also confirm where the 'seal' is in the system, so I can better understand where the leak may be coming from? I'm assuming nothing should be getting past that plastic diaphragm, and that's the cause of my issues.
Sorry for the long post, just wanted to be as thorough as possible
Here is a pic of the MC for reference. Ignore the zip-ties...it's how I decided to hold things in place while setting that clip.
Hopefully I can get this fixed ASAP without too much cost...money is an issue these days and I'm hoping to get the bike on the road as a commuter since my car is soon to be on the mend.
I'll probably get flamed for saying this...but if I just need some patience and should keep attempting to bleed the line, please do say so. If the brakes can function with this small of a leak, I may ride it til I can source the parts I need to fix it properly. Just don't feel like chasing my tail if that's an impossible task.
