Author Topic: going crazy with wiring. 75 750K brown wire in headlight bucket ???  (Read 2507 times)
Offline greenjeans
  • 1972 CB750K2
Trying to sort out the wiring on my 75 750K.  Long story short, it had bags etc came with no head light.  The wiring that attached all the lighting on the bags and faring was well done.
Got the bike running last week.   Went to put on a headlight and that's where the fun begins...
In the headlight bucket, I have a female brown wire.  On my diagram I don't see what it could be.  From the fuse box, the wiring diagram shows 2 brown wires leaving it.  One goes straight to the tail light, the other goes straight to the ignition switch.
From the stray wire in the bucket, there is continuity between it and all the other brown wires. (at the fuse box and the ignition switch)
I can't get the tail light to light up with the head lamp.   The bulb is good.
Any ideas ?
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Re: going crazy with wiring. 75 750K brown wire in headlight bucket ???
« Reply #1 on: April 21, 2011, 06:22:46 PM »
Just curious... do you have continuity from the tail light to the 15 amp fuse with the battery disconnected and the key on? Its a direct shot once the key is on.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline rklystron
« Reply #2 on: April 21, 2011, 06:27:53 PM »
If your bike is a K2 the tail light comes right off the ignition switch (Brown wire) TL2 is the connection
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
Offline cookindaddy
  • I sure love this bike!
« Reply #3 on: April 21, 2011, 07:09:35 PM »
Yes, but the current for the brown wire comes from the taillight fuse (at least it does on the 77/78). The brown wire is associated with the Park position of the ignition switch and allows you to only have on your rear lights if you are Parked.
I had thought that the loose ended brown wire in the bucket was for an accessory, so that you could listen to your radio or CB while you were parked but someone else thought that it was for a European requirement of some sort. You could use it for a radio.
Check the circuit a bit more and satisfy yourself where the current comes from in the brown wire and you will likely find the cause of the taillights not coming on. Check the taillight fuse?
« Last Edit: April 21, 2011, 07:11:59 PM by cookindaddy »
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
« Reply #4 on: April 21, 2011, 10:51:42 PM »
In the UK you legaly have to have a front "Sidelight" which is a 5watt bulb in the headlamp reflector(which also has a replaceable main bulb) and the brown wire is for this, along with a different RH switch which alows for lights OFF--SIDE--MAIN/DIP
« Reply #5 on: April 21, 2011, 10:59:57 PM »
Most (not all) K5 bikes have a Brn/Red wire from the headlight START button circuit that runs back to the fuse. The other side of this fuse will have typically a Brn/Red or Brn/Wht wire that returns to the headlight bucket. From there it goes to the left handlebar Hi/Lo switch and returns as Wht for Lo and Blu for Hi Beam. That's about it...
Sometimes the Brn/Red from the START button may be Blk/Red or Blk/Yel instead, and that color will run back to the middle fuse. So, checking the middle fuse's wire colors will help you see where it's coming and going with the headlight. When you look at the fuse as mounted, the power from the START button (in the relaxed position) comes into the left side of the middle fuse, goes out to the headlight bucket on the right side.  :)
Offline Silverback
« Reply #6 on: April 22, 2011, 09:25:00 AM »
A few of the headlight buckets I have been into have a jumper from the the black (usually a female four input connector) to the brown tail light. This turns the tail light on when you turn the ignition on. Sounds like this jumper is not connected. Can't remember the color off hand, but I think it is a very short red/black wire. Look to see if you have a jumper from this black wire connection that is not connected. If it isn't, hook it up to your female brown connector. This should do the trick.
« Last Edit: April 22, 2011, 09:34:22 AM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
