Author Topic: Preparing rear brake drum  (Read 895 times)
Offline zabzob
« on: April 22, 2011, 07:29:56 PM »
Got the back wheel off in preparation for doing the sprockets and brakes. The brake drum is a bit rusty and very dusty. Also looks kinda shiny. What's the best way to prepare it? Sandpaper?
1975 CB750K5
Offline Johnie
Re: Preparing rear brake drum
« Reply #1 on: April 22, 2011, 07:35:17 PM »
Yes, get some rough paper and rough it up good and blow it out. You will not hurt it. You do not want it shiney in there or you may end up with squealing.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
DH
« Reply #2 on: April 22, 2011, 08:56:35 PM »
And take care not to breath any of the dust that will result. Nasty stuff, and a health risk.
Do it outside and finish off with aerosal can of brake parts cleaner.
KingCustomCycles.com
« Reply #3 on: April 23, 2011, 02:29:45 AM »
If you haven't put it back together yet, a small amount of lube on the brake pivot shaft and the springs will keep them from rusting and getting tight. The shaft has a felt seal on the outside to hold oil and resist moisture.
