Author Topic: RH Handlebar Switch Block Identification  (Read 1856 times)
Offline nayto550
« on: April 25, 2011, 05:34:56 AM »
Here's a pic of the right hand switch on my 750 F1.  It appears to be OEM, but I'm pretty sure it's not original to this bike.  It has an on-off for the lighting and a notch in the lower half for wiring external of the handlebar.  Can anyone ID what this switch belongs to?
Thanks!
« Last Edit: April 25, 2011, 05:51:43 AM by nayto550 »
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline OldSchool_IsCool
  • Really feeling like an
Re: RH Handlebar Switch Block Identification
« Reply #1 on: April 25, 2011, 06:36:45 AM »
Might be from an early K, before headlights were required 24x7
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline CycleRanger
  • No comment about being an
« Reply #2 on: April 25, 2011, 06:52:48 AM »
Does it have a hole in the bottom near the grip?
If so then it's likely from an earlier K.
« Reply #3 on: April 25, 2011, 08:18:07 AM »
KO were single thottle cable, had OFF , ON,
HI and had a black kill knob That is a 73 or later style, probably later looking at kill button. I think 77/78 had wiring outside the bars. Is the hole factory or PO added, check the color on edge of the hole.
Offline nayto550
« Reply #4 on: April 25, 2011, 03:22:23 PM »
It is a push/pull throttle, the wiring cutout is definitely factory, and it has a threaded hole between the cable holes (possibly a Harley-style throttle lock screw?).  I think 74 was the last year for headlight switches (I could be wrong), so I guess it's probably from a 73-74 K.
1976 CB550F
1988 HD FLHS
Offline CycleRanger
« Reply #5 on: April 25, 2011, 04:04:23 PM »
Yeah that threaded hole is for the "throttle friction adjustment screw", Honda called it something like that.
They seemed to have phased out the headlight switch in '75 as I've seen stock '75's with and without the switch.
(My K5 has the headlight switch but no adjustment screw, this version is kinda rare.)
So, looks like your control was replaced at some point.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: April 26, 2011, 09:32:54 AM »
Pre- 1976 regardless. Both 550K and 750K use the same control and had no light switch.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
