Well I'm on the skids now! A couple of weeks ago I was riding home from work on Kate and was running about 45 MPH on a city through-way at 0600 hours, when the back wheel locked up. It was still dark and was misting lightly and I really couldn't see what had happened. I rocked the bike back & forth a bit and it broke loose, I drove it to an intersection and look it over but still could not see what the problem was, all seemed ok so I continued my ride home, parked it, and went to bed thinking that I would look it over good when I woke up.......
When I did wake up, I had a raging case of pneumonia that landed me in the hospital.
![Tongue :P](http://forums.sohc4.net/Smileys/default/tongue.gif)
Yesterday I finally had a chance to look Kate over. NOT GOOD! The mounting brackets had broken on the aftermarket chain guard The and the chain had launched the guard forward into the cases!
![Embarrassed :-[](http://forums.sohc4.net/Smileys/default/embarrassed.gif)
both upper and lower cases are cracked right through the mating surfaces, and there is a hairline crack that almost touches the output shaft seal.
![Lips sealed :-X](http://forums.sohc4.net/Smileys/default/lipsrsealed.gif)
I guess I'll be looking for a new/used engine.
![Undecided :-\](http://forums.sohc4.net/Smileys/default/undecided.gif)
(although I'm thinking about trying JB weld on it and see if I can get by until fall?)
