Author Topic: Why would the choke act in the opposite manner as intended?  (Read 1384 times)
Offline Beastman
« on: April 25, 2011, 12:18:52 PM »
Here are the facts:
1978 cb550k: 4 into 1 yoshi rep pipe. Bigger jets (went from 90 to 95), needle clip moved to center notch.  Cleaned carbs, cleaned gas tank rust.
My bike's choke now works opposite.  If the bike is idling at 1200 or so, and I turn on the choke, it does.  Any idea why this would happen?
I know this is prob not enough info.  Please ask for specifics if this is too vague.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Why would the choke act in the opposite manner as intended?
« Reply #1 on: April 25, 2011, 12:20:59 PM »
Why would you put on the choke when it's already warmed up?
If it's warmed up, you are bogging it down with too much fuel when you use the choke.
No.
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #2 on: April 25, 2011, 01:23:40 PM »
Sorry, no input..................but where did you get the replica Yoshimura pipe?
Follow my build "P38 Racer" in Project section
Offline Beastman
« Reply #3 on: April 25, 2011, 06:00:32 PM »
I can't start the bike with the choke.  I have to raise the idle for the bike to start. Then turn the idle back down once it's run for a bit.  The choke used to get my bike up around 3000 rpm, now it just kills it.
Offline nayto550
« Reply #4 on: April 25, 2011, 06:07:11 PM »
Was air intake modified at all (high-flow filter, pods, etc.) when you did the pipes and jetting?
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline phil71
« Reply #5 on: April 25, 2011, 06:08:36 PM »
is this a CV carb?
Offline Beastman
« Reply #6 on: April 26, 2011, 09:58:38 AM »
No mods to the airbox.  Besides disconnecting and reconnecting at the rubber boots.
The carbs are PD keihin carbs.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #7 on: April 26, 2011, 02:03:03 PM »
It sounds like you've got it rich enough to not need choke to start, especially now that it is warming up outside in most places.
Choke is just too much fuel now.
« Last Edit: April 26, 2011, 02:05:20 PM by mlinder »
No.
Offline vames
« Reply #8 on: April 26, 2011, 02:56:51 PM »
Sounds like you're trying to use the choke as a sort of fast-idle mechanism, which it isn't (unless later models have a fast idle cam that earlier ones didn't). If the bike is already started, you don't need the choke. Many of our bikes take a few minutes or a few blocks riding to warm-up before they'll idle on their own -- for that, we typically keep a hand on the throttle and keep it running. Soon enough it's warm and idles on its own.
Offline Beastman
« Reply #9 on: April 27, 2011, 07:24:21 PM »
I was under the impression that the main jet/needle did not effect fuel delivery at idle.  Only when the throttle is opened up.
Offline 333
  • Time for change
« Reply #10 on: April 27, 2011, 07:35:31 PM »
I would start over.  What told you to re-jet it and change the needle?  Sometimes a new pipe requires no re-jetting, and if it does, it could go either richer or leaner.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Beastman
« Reply #11 on: May 03, 2011, 10:37:47 PM »
I was told by some reliable guys here that the PD carbs run lean, and even leaner/hotter with an open exhaust.
Maybe I will start over.
Offline MasterChief750
  • Detonation
« Reply #12 on: May 04, 2011, 04:41:47 AM »
my pds run really rich from the factory. if your choke is killing it on startup and you dont need it to start it your carbs are rich. have you done a plug chop at all?
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
