Author Topic: <<<the simple little question thread>>>  (Read 18271 times)
Offline Duperts
  • Pomm in the outback
Re: <<<the simple little question thread>>>
« Reply #100 on: June 11, 2011, 03:00:55 AM »
Hi guys, long time lurker, first time poster.
I have a question regarding the exhaust systems. Forgive all noobism.
Whats the difference between exhausts, for instance 4-2-1, 4-1, 4-2, etc?
Is there any performance gain, volume, deeper pitch... or is it purely different exhausts do diff things?
Cheers n ta
Set an example on your 2 wheels for the next generation to follow.
Offline 76CB5WI
  • CHRIS
« Reply #101 on: June 11, 2011, 08:22:34 AM »
Cheers n ta
Answer: Noise and style
« Last Edit: June 11, 2011, 08:25:29 AM by 76CB5WI »
87 FJ1200
72 CB750
76 CB550
Offline Frankenkit
  • Industrial Strength
« Reply #102 on: June 11, 2011, 09:24:11 AM »
Quick one.
Working on a friend's bike.  #14 on the fiche is shot, literally snapped in half.  Can I replace it with the same diameter fuel line from Napa, or do I NEED to order from Honda due to the 90 degree bends in it? (i.e. would you expect it to kink off if I tried just regular fuel line?)
« Last Edit: June 11, 2011, 09:29:23 AM by Industrial Kit »
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
« Reply #103 on: June 11, 2011, 09:28:09 AM »
Back in the a days these bikes were current, 4-1 were performance plays. There were shoot-outs in the magazines where they fitted CB750s with all the different pipes, did some minor jetting and ran them down the dragstrip. To the winner went the spoils (sales). RC Engineering was often the top pipe, and sales, with Jardine giving them a run. jardines suffered in the looks category and didn'tsell too well IIRC.  After Jardine sold out and RC closed, Kerker bubbled up as the strongest pipe mostly on their reputation with the larger 1000cc SuperBike racing series, as the 750 class was losing popularity.
Yoshimura's pipe was perhaps the strongest, but they didn't offer a street legal version so it was often excluded from these tests.
Nowadays, it seems to be mostly a looks and convenience contest. Mac wins for economy, but I wonder about the performance. Seldom if ever tested. 2-1s are good for bikes that want throwover soft bags or hard bags. Ground clearance suffers, but judging from comments on this forum, that's the furthest from most peoples minds.
The new(er) CycleX 4-2-1 is interesting. Why go to the trouble if not to produce better power and clearance? Their's may be a good offering. I'd like to hear and see a test.
« Last Edit: June 11, 2011, 09:30:21 AM by MCRider »
« Reply #104 on: June 11, 2011, 12:17:13 PM »
Quick one.
Kit, you could also try finding some metal brake or fuel line (or transmission cooler line) of the correct size and bending it yourself.   It will be cheap and easy to cut but may take a few trys bending it that tight without kinking it too badly...
Offline Grnrngr
« Reply #105 on: June 11, 2011, 10:57:56 PM »
Dpending on where the bad places are on the original line, looks like you might be able to patch it with some appropriately sized fuel line..how is the original damaged?
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline db22
  • Old and in the way.
« Reply #106 on: June 12, 2011, 06:46:19 AM »
Anyone know of a good clear fuel-proof coating that protects new tank decals from gasoline?
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
bollingball
exh pipes
« Reply #107 on: June 12, 2011, 07:40:11 AM »
Dupert I have the four into two I like the look slash cut on the end they were on the bike from PO no data on them but look like Mac don't know what is inside them but they have just the sound I like deep and throaty but not loud. carbs and filter are all stock I do have a K&N when it comes time to change those Honda filters are $40.00 plus at my dealership.
+1 76CB75WI
                      Ken
Offline Tintop
« Reply #108 on: June 12, 2011, 08:00:06 AM »
Good thread idea. Here's a simple little question:
I got a UNI foam filter for my '76 550 but I forgot to order the oil that goes with it. So what can I use to oil it up? And do I just spray it all over the thing?
I'd go with filter oil - it's sold in either aerosol cans or in liquid form at pretty much all dealers and some auto parts stores.  Brand specific isn't all that important (ie, K&N on a UNI filter) though some may disagree.
Do not use 'cloth filter' oil (K&N) on foam.  There are both filter oils & cleaners made specifically for foam, a can of each will last years.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline extek66
« Reply #109 on: June 12, 2011, 08:08:22 AM »
[/google spraymax]
Offline Frankenkit
« Reply #110 on: June 12, 2011, 09:08:23 AM »
It snapped in half.
1973 CL350- Lola?
Stuff for sale
Offline armour
« Reply #111 on: June 12, 2011, 09:13:41 AM »
Checking oil - screw dipstick in ?
Plug gap with Dyna , pods, Mac exaust and 5 ohm coils , CB400F ?
Best chain to use ?
Stock motor, which octane fuel with the above setup ?
Will teflon tape wrapped around a weeping bleeder valve break down and fail ?
Just to ask a few........ :D
« Reply #112 on: June 12, 2011, 09:51:17 AM »
No
Stock spark gap
Best chain to use ?
Not simple to define substitutes other than stock recommendation.  It is rare that personal opinions are based in foundational fact.
When in doubt, the bike manufacturer knows best.
Regular
Unlikely.
Teflon tape would be misused as a thread anti seize, as the threads only seal fluids (poorly) during bleed operations.
If it is leaking, the leak is at the taper end-to-seat interface.  And you DO NOT want to put teflon tape there unless you are hiding defects from a prospective buyer.
Also, don't ignore the importance of the rubber dust and water ingress blocking cap.  It's absence is probably the leading cause of the bleeder seizing in the caliper and corrosion down at the tip to seat interface.
Offline armour
« Reply #113 on: June 12, 2011, 12:09:05 PM »
^ Thanks for the reply, in depth !
I have more, but electrical specific which I have a wall in the brain to fully understand.
I will post when ready !  ;)
Offline Grnrngr
« Reply #114 on: June 12, 2011, 09:27:36 PM »
It snapped in half.
If the long piece broke in the middle, just trim the ends and find a piece of fuel line that will fit over it. Couple small hose clamps, just like downtown.
'77 CB750A
Offline Coyote13
« Reply #115 on: June 24, 2011, 07:08:35 AM »
Here's a quick one guys.  K8 750, trying to change my front sprocket.  Is it possible to get the sprocket cover off without removing the shifter cover? Is there a trick I'm missing, or will I be in the market for a new shifter cover gasket soon?
TIA
Kyle
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
« Reply #116 on: June 24, 2011, 01:07:22 PM »
...pretty sure I've done it before on a K2 :)...but that shifter cover is gonna make sprocket removal a bit of a pain >:(
Offline Coyote13
« Reply #117 on: June 24, 2011, 01:09:13 PM »
A very serious pain actually, I don't think it's possible.  I've tried every angle I can come up with and nothing's working.  Guess I'll be needing a new gasket....
