Author Topic: Where does the CB650 throttle cable attach at the carb?  (Read 5184 times)
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« on: April 15, 2006, 10:42:47 AM »
I friend of mine just bought a 1980 CB650SC. The throttle was sticking so we decided to take the throttle cables off and lube them, checking the usual suspects as we went. I didn't take off the lower cable at the carb, and now I can't see where it attaches to put it back on. It looks like a pain...Does anyone know if I'll need to loosen\remove the airbox or loosen the carbs to get to it?
The manual is on it's way, but I'd like to get it together in the meanwhile.
Thanks in advance!
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline crazypj
  • I'm brill, me
Re: Where does the CB650 throttle cable attach at the carb?
« Reply #1 on: April 16, 2006, 04:04:52 PM »
its a pain even with the carbs off. get an extra long bent needle nose pliers. the cheap made in china will do, dont need anything that could damage the cable
PJ
Offline cb650
« Reply #2 on: April 16, 2006, 04:37:39 PM »
Yes on bike they are a pain.  How did you get them off?
           Terry
Offline rab1dwolf
« Reply #3 on: April 16, 2006, 08:20:38 PM »
I always remove my throttle and choke cables with the carbs still on the bike.  Hell I've adjusted them with the tank still on but just propped up.
My suggestion: learn how to see with your fingers.  visualize what you feel and imagine it and its alot easier then relying on the eyes. small hands help as well.
1982 cb650sc nighthawk.  the work never stops.
Offline scott_cb650
« Reply #4 on: April 17, 2006, 07:46:04 AM »
Here are a few pictures that might help.
I have the rest of the chapter in .jpg if you want me to send them to you.
Why worry about tomorrow for tomorrow has enough troubles of it's own.
Offline scott_cb650
« Reply #5 on: April 17, 2006, 07:46:53 AM »
Offline pmpski_1
« Reply #6 on: April 17, 2006, 10:43:37 PM »
Thanks guys - I didn't take the bottom one off, so I didn't see where it came from. I've done my CB550 more times than I care to remember and I'm sitting here scratching my head because the CB650 is ... well ... different.
I have the Clymer manual tonight, so I'll give this a shot tomorrow. Crazypj, I guess I have a good reason to go buy another tool  ;D Funny, I grew up with my dads tools - he had EVERYTHING. Now I approach a problem and visualize which tool I need, then start cursing because I realize that I'm visualizing some tool that my dad has, 2000 miles away.
Offline cb650
« Reply #7 on: April 18, 2006, 03:51:00 AM »
You dont need a special tool.   The bottom cable goes underneath the same "disk" that the top cable goes too. Down under the bottom and more than halfway up the back and there is a hook.
The "fingers" of the hook are very long.   Have fun.
          Terry
Also heres the steps I go through.    Assemble the cables and throttle at handlebar.   Rout cables so they leave extra length.   Hook cable ends in the hooks on the disk then slip adjusters in brackets.
« Last Edit: April 18, 2006, 04:08:40 AM by cb650 »
