Author Topic: Dorothy III - CB750  (Read 104957 times)
Re: Dorothy III - CB750
« Reply #325 on: October 01, 2015, 06:41:52 AM »
How do you get out the spring pin that holds the kickstart shaft? Number 9.
ITs a bear. Many threads on this, when I did mine a few years ago. Settled on a small vicegrip; squeeeze what bit of the pin you can reach and tap up on the vice grips. Once it moves, reposition the VG to grab a little more and repeat.
« Reply #326 on: October 01, 2015, 06:44:50 AM »
Thanks!  I will take my time, left it aside yesterday.
« Reply #327 on: October 01, 2015, 06:57:02 AM »
Oh yeah, I remember now. Once setting the vice grip, I used a long screwdriver (maybe it was a tire iron) to pry on it. There was some point that made an obvious fulcrum. Once it moves, reposition the grips and repeat.
Offline MoMo
  • Ride like you're invisible
« Reply #328 on: October 01, 2015, 07:34:30 AM »
Certainly are worn.  Won't a pin punch drive that out?  Remember I have a later model trans complete...Larry
« Reply #329 on: October 01, 2015, 07:36:49 AM »
Right!  You do.  I suppose they are compatible 1970 - 1975, right?  I will buy it from you.
« Reply #330 on: October 01, 2015, 07:39:07 AM »
That pin can only go one direction. If you tap on it it stops against the floor of the hole its in. It must be withdrawn.
I think I'm remembering correctly.
Offline MoMo
« Reply #331 on: October 01, 2015, 07:45:46 AM »
K7/8 trans, maybe someone knows compatibility issues, I don't...Larry
« Reply #332 on: October 01, 2015, 07:48:44 AM »
I will check into it.  Maybe invidual gears can be replaced only.
« Reply #333 on: October 01, 2015, 03:21:31 PM »
The sprocket shaft is different, The K7-8 is longer if I remember correctly. It could be used but the chain will not align correctly with the rear sprocket.
Offline MoMo
« Reply #334 on: October 01, 2015, 05:00:27 PM »
If the gears are the same , it'd be a cheap fix for Prokop as I'd sell real cheap
« Reply #335 on: October 02, 2015, 04:30:05 AM »
I will do my reaserch and get back to you, Larry.  I could be only swapping gears, keeping shafts.
« Reply #336 on: October 02, 2015, 04:31:41 AM »
I took apart the head, Frank was right. knee mill is the easiest way to compress valve springs, it worked like a charm.
In K0 style, no guide seals on intake side - I removed two already here.  Loved the tight fit of under the spring washers, they were hard to remove because of tight tolerancies.
« Last Edit: October 02, 2015, 04:35:46 AM by 70CB750 »
« Reply #337 on: October 02, 2015, 04:40:39 AM »
The underside.
« Reply #338 on: October 02, 2015, 04:42:15 AM »
Got it out yesterday, vice grips and twisting motion worked easy enough, thank you.
« Reply #339 on: October 02, 2015, 04:47:28 AM »
This was my Robinson Crusoe moment; somebody worked the intake the way Hondaman describes in his book.
« Last Edit: October 02, 2015, 04:53:35 AM by 70CB750 »
Offline calj737
  • I refuse...
« Reply #340 on: October 02, 2015, 04:52:34 AM »
perhaps an answer as to why #4 would not synchronize equally with the others? A DIY porting job that created unequal port flows. Apologies if you previously stated the rebuild specs, but what is the intention on the motor? Stock rebuild or "turned up" a touch?
« Reply #341 on: October 02, 2015, 05:05:25 AM »
Could be the porting job; also I remember once she ate the pin from the carburetor choke flap door; I found only the flap inside the carburetor but there are no siginificant nicks on valve or valve seat.
Plans for the engine:  if possible I will only hone and install new rings, depends how worn out cylinders are; with only minor improvements such as aftermarket tensioner and replacing worn out parts.
She had all the power I cared to use and more  ;)
Now the valves have dimples where the tappet adjuster pushed on them, I may need to replace all the valves.
Offline calj737
  • I refuse...
« Reply #342 on: October 02, 2015, 05:50:53 AM »
Ouch! If the prices of those is anything like the 5xx models  >:(
« Reply #343 on: October 02, 2015, 05:59:43 AM »
Not sure how much 5xx go for, but the SuperSport engine was the worst - valves, springs, retainers and guides plus 2 Neway cutters.
Looks like CycleX can fix me for reasonable price:
ENV-015    $149.00 per set of 8 (4 Intake and 4 Exhaust)
Offline calj737
  • I refuse...
« Reply #344 on: October 02, 2015, 06:29:35 AM »
$40@
« Reply #345 on: October 03, 2015, 07:45:32 AM »
Cleaned pistons.
« Reply #346 on: October 03, 2015, 07:47:43 AM »
This is how one of the rings came out, looks like the little piece was riding there quite happily for a while, the break surface is not fresh.
« Reply #347 on: October 03, 2015, 07:51:09 AM »
Oil rings - I never seen oil rings like these before.
And the inner and outer rings were all lined up, meaning the gap was open.
« Reply #348 on: October 03, 2015, 08:18:58 AM »
Crankshaft out of the way and safe.
« Reply #349 on: October 05, 2015, 04:49:48 AM »
The engine stand needed some additional fabrication.
