Author Topic: Dorothy III - CB750  (Read 107290 times)
Offline jgger
Re: Dorothy III - CB750
« Reply #425 on: January 27, 2023, 06:31:20 PM »
Well I would say that is tight! Good job, give yourself a pat on the back.
« Reply #426 on: January 28, 2023, 04:43:33 AM »
Thanks 😊
« Reply #427 on: January 28, 2023, 06:30:53 AM »
Little bit more lapping, tested with rubbing alcohol and not a single drop in two hours.  Done with that one, now what?
Nice! That works.
« Reply #428 on: January 28, 2023, 06:55:10 AM »
I'd say you are due a cold beer! Well done Mate...
« Reply #429 on: January 28, 2023, 07:02:44 AM »
That's given  ;D
But what am I going to do about cylinders and pistons, that is the question.
« Reply #430 on: January 28, 2023, 07:18:48 AM »
That's given  ;D
I have always entrusted my machinist to accurately measure the bores to determine exactly what is needed. Hopefully just a hone and re-ring as boring [$50+ x4] and a piston kit [$200+] can get expensive.
I'm a "Wiseco Piston" guy but many guys, including Hondaman, have had success with the Cruzinimage piston kits.
https://www.ebay.com/itm/165843069051?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1MHJOWr_xQOiMs6nIZusdnQ42&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=165843069051&targetid=1644837434363&device=c&mktype=&googleloc=9028253&poi=&campaignid=16743749222&mkgroupid=138744546207&rlsatarget=pla-1644837434363&abcId=9300842&merchantid=101648401&gclid=CjwKCAiArNOeBhAHEiwAze_nKC9QxjYoZ9NBRLC0n-E38JFFcrAo3siPTAykdpf_rOIwhpClE6kEuxoCuAcQAvD_BwE
« Reply #431 on: January 29, 2023, 03:53:36 AM »
That's given  ;D
Aren't you a machinist, too?  :D
I did new rings and hone for Red but I read from Hondaman that it is only short term solution - good for 15K or so.
« Reply #432 on: January 29, 2023, 06:49:57 AM »
After I repair the bent fins on my S/C project I’m giving it a light home to get back a decent crosshatch. If the new RIK rings (std.) measure with spec gap, the original pistons are going back in. I feel th simplest solution is always the best..... At my age, 15000 miles is good!
« Reply #433 on: January 29, 2023, 07:44:42 AM »
That's given  ;D
I was a machinist, but that was many moons ago!  I now leave it to the Pros...
« Reply #434 on: February 17, 2023, 08:22:21 PM »
Steve-O:
I'm curious, as I worked in several machine shops (I was the Controls guy who made the machines they built 'go') and would like to have a Bridgeport or similar mill: would you consider a mill rigid enough to bore these cylinders accurately? Mine are currently being done in a [large] engine boring machine with things like 3" thick top and side plates and 5" thick bottom plate, boring 1 hole at a time (used for inline car engines). It is rigid like Gibraltar!
« Reply #435 on: February 20, 2023, 07:05:46 AM »
Steve-O:
Hey HM...I never did cylinder boring but my machinist uses an automotive type boring machine too.  I'd say that is the best way to go.
« Reply #436 on: February 22, 2023, 05:38:25 PM »
Steve-O:
One of the machinists at my former employer decided to rebuild his Trumpet Bonneville twin after it sat for 30+ years. He made a 1" thick mounting plate for it to bolt onto the head of the biggest lathe in the shop, then bored each cylinder using a specially-made (he made it) bit holder in the traveler. Then he took a video of it being bored, which I had until my 2nd-to-last computer just stopped working one day, before I had backed up that video file. :(
It looked pretty cool, never saw it done that way before. It worked fine, too.
« Reply #437 on: February 25, 2023, 03:39:00 AM »
Steve-O:
I have seen something like that many times in the tool and die factory.  Aluminum casting form had always inserts made from tool steel while the form "frame" (say 1000 x 1000mm) was made from cheaper steel.  On a big, big lathe this old timer would bore the hot aluminum entrance inserted in the frame.
Ways to get by before CNC.   :)
Online Don R
« Reply #438 on: February 28, 2023, 11:00:00 AM »
I guess this will come handy  ;)
  I printed this "cb750 changes" to hang in the garage next to the serial number list.  The link didn't come along with the quote.  Reply #413.
« Last Edit: February 28, 2023, 11:02:43 AM by Don R »
« Reply #439 on: June 13, 2023, 08:56:00 AM »
I made  bushings for the swingarn.
« Reply #440 on: June 13, 2023, 02:39:35 PM »
Any good Bridgeport (not worn out) mill should work with a good stiff setup. The sleeves are pretty easy stuff to cut, not a lot of fuss or chatter.
« Reply #441 on: June 13, 2023, 04:11:13 PM »
I used my old Logan to make bushings.
Here is the future swingarn.
« Reply #442 on: June 13, 2023, 05:09:46 PM »
Custom made swingarm ?
« Reply #443 on: June 14, 2023, 04:09:40 AM »
I got it many years ago from ebay. Suzuki swingarm, I think.  We shall see how it turns out.
« Reply #444 on: June 14, 2023, 06:23:50 AM »
Why the need for a new swinger?
« Reply #445 on: June 14, 2023, 07:19:32 AM »
Challenge?  ;D
The plan for Dorothy is to look stock but with improvements when you look closer.
« Reply #446 on: June 14, 2023, 11:20:22 AM »
The swingarm looks very much like the ones that come on the Suz. GS1100E
« Reply #447 on: June 27, 2023, 07:05:16 AM »
After several tries, I got the angle right.  Now the length.  I might make it 1" longer than the stock swingarm.
« Reply #448 on: May 07, 2024, 06:07:30 AM »
Welded the donner seat bracket back on.  The frame will get stripped and powder coated.
« Reply #449 on: May 07, 2024, 06:54:20 AM »
Color?
