Author Topic: Dorothy III - CB750  (Read 104454 times)
Re: Dorothy III - CB750
« Reply #475 on: May 07, 2024, 07:54:02 AM »
Many paints are called semi gloss and they vary a lot, I think Dupli Color is close.
I have used POR15 chassis black to good effect but lately I have had some bad batches or something and it did not go on well. I think I got an old can of it.
« Reply #476 on: May 07, 2024, 04:47:37 PM »
In my experience a gloss black single stage is gonna be just a bit too glossy when new.  After a couple vigorous cleanings, a perfect match.
« Reply #477 on: May 07, 2024, 06:24:08 PM »
I've been wondering for a while when they're going to put a date code on these cans of paint which can be read by the consumers: Us  >:(
« Reply #478 on: May 07, 2024, 09:42:52 PM »
I used POR15 on my CJ7.  Good stuff.  But I need to outsource the frame to speed things up and the company will strip it and powder coat it.
« Reply #479 on: May 08, 2024, 08:13:17 PM »
I've had that problem with the POR paint, too. It doesn't seem as reliable and excellent as their POR15, which I've used to save several tanks. That stuff rocks.
« Reply #480 on: May 09, 2024, 07:59:20 AM »
Yes, not sure I'd do another frame with it unless I tested whichever can I opened. It doesn't seem to want to level out very well.
« Reply #481 on: May 11, 2024, 12:37:19 PM »
I wondered that, too, until I was the engineer building a machine that included putting date-codes and barcodes onto finished products. It turns out, the date code is coded and standardized so machines can read it: only those manufacturers who decide on purpose to make it visible to the public in text bother to add more printer capability to their machines (expensive at best, and only available since about 2008!). In the beginning (1990-ish) the scanners could only read bars and spaces, which brought us the common 'scan code' you see on all products now. A scanner that can also read text characters is about 10x more expensive than a barcode reader, so the scenario continues...  :-\
« Reply #482 on: May 11, 2024, 02:07:14 PM »
This makes it almost impossible to trust the vendors of these aerosol spray paint cans.
I don't like doing prep twice.
Offline willbird
« Reply #483 on: May 12, 2024, 02:00:16 AM »
one past job the company worked on parts for general motors. we put a serial number on the parts which included the letter designating the machine it was run on, Julian date, and a part number for that day which incremented up. the pin stamp device had “dot” and “smooth”…the cameras in 2008 could not OCR read “smooth” only “dot” could be read. a few years into the job they made us add a 3D bar code. only recently learned the difference between 2D and 3D. we called them 2D but being stamped they were actually 3D barcodes
« Reply #484 on: May 12, 2024, 08:01:43 AM »
Do you think NAPA would have a bar code reader to check the date/code ?
Offline willbird
« Reply #485 on: May 12, 2024, 01:47:09 PM »
A normal QR code you can read with a smart phone ?? tons of free apps
« Reply #486 on: June 05, 2024, 07:51:17 AM »
Mocking up the powder coated frame
« Last Edit: June 05, 2024, 07:52:53 AM by 70CB750 »
« Reply #487 on: June 05, 2024, 07:52:06 AM »
The wheel came from IKEA.  :)
« Reply #488 on: June 05, 2024, 08:06:33 AM »
What??!!!!!    And I assume you have another swingarm?
« Reply #489 on: June 05, 2024, 08:08:51 AM »
Yup, there should be a different swingarm if everything works out.
« Reply #490 on: June 07, 2024, 07:34:53 AM »
After several confused attempts I decided to practice with an old rim.
« Reply #491 on: June 07, 2024, 11:38:38 AM »
Looks like you got the hang of it...
« Reply #492 on: June 07, 2024, 04:02:20 PM »
Seems like it.   :)
Now gotta build a truing stand and get a torque wrench.
« Reply #493 on: June 07, 2024, 04:30:49 PM »
Looks good Prokop.
Which spokes are those,Sapim brand,or stock Honda?
« Reply #494 on: June 07, 2024, 05:42:51 PM »
Looks good Prokop.
Thank you.
SS spokes from Buchanan.
« Reply #495 on: June 07, 2024, 08:46:26 PM »
How much was the Buchanan set now?
« Reply #496 on: June 09, 2024, 04:40:50 PM »
Spokes + nipplee: $159
« Reply #497 on: June 10, 2024, 06:24:51 AM »
Looks good Prokop.
You'll never regret buying them...
« Reply #498 on: July 02, 2024, 03:53:14 PM »
Still truing the rim.  Finally made me a truing stand.
Offline calj737
  • I refuse...
« Reply #499 on: July 02, 2024, 03:56:01 PM »
You gotta love the 1,001 uses for angle iron! Such a versatile material shape.
