Author Topic: Dorothy III - CB750  (Read 348948 times)
0 Members and 13 Guests are viewing this topic.
Re: Dorothy III - CB750
« Reply #475 on: June 09, 2024, 04:40:50 PM »
How much was the Buchanan set now?
Spokes + nipplee: $159
« Reply #476 on: June 10, 2024, 06:24:51 AM »
Looks good Prokop.
Which spokes are those,Sapim brand,or stock Honda?
SS spokes from Buchanan.
You'll never regret buying them...
« Reply #477 on: July 02, 2024, 03:53:14 PM »
Still truing the rim.  Finally made me a truing stand.
« Reply #478 on: July 09, 2024, 04:27:52 AM »
You gotta love the 1,001 uses for angle iron! Such a versatile material shape.
Exactly.
« Reply #479 on: July 09, 2024, 04:36:02 AM »
Truing the wheel I started to freak out.  It seemed like I will never get it right.
This morning  I took a dial indicator to see how bad it was.
0.74 mm axial and 1.2mm radial.  I can live with that.   :)
For the kicks I checked the old rim from Dorothy. 2.7 mm and 1.35mm.
« Reply #480 on: July 09, 2024, 07:05:54 AM »
Prokop,have a look at putting the pointer inside the rim,along the bead area;that area is the most accurate.
« Reply #481 on: July 09, 2024, 07:46:20 AM »
Thats what i did.
« Reply #482 on: July 10, 2024, 06:32:54 AM »
[/quote
How do you stop the axle from shifting left or right?
P.S. I pulled two old metal bed frames out of a scrap bin last week. Great source of free material!
« Reply #483 on: July 10, 2024, 07:08:30 AM »
I pulled many things from the scrap bin - even though it is illegal in our county.
I wrapped masking tape on the axle and that helped.   For the final check I held the axle and let it spin on wheel bearings.
If there is a trick to it, I am all ears, sir.
« Reply #484 on: July 10, 2024, 07:52:13 AM »
Frustrating, are the bearings ok?
« Reply #485 on: July 10, 2024, 08:19:20 AM »
20-30+ yrs. ago persons could walk around the county landfill areas without anyone telling them 'that's against the rules'. Very upsetting how they have messed things up now.
Prokop,what's their reason for saying it's illegal to remove an item ?
« Reply #486 on: July 10, 2024, 11:09:58 AM »
There used to be trash-to-treasure sharing area at the landfill but some people would hang there all weekend to get items for yard sales and such.  Now you can leave it and it gets donated to a local thrift store and money from the sale goes to the county food bank.
But once you drop it in the trash or recycling container, it belongs to the county and it is illegal to take it.
« Reply #487 on: July 10, 2024, 11:12:22 AM »
What you could have done, is move the rollers to the inside of the angle iron at the proper width of the axle spacer to hold the rim/hub centrally. Then lateral movement would have been restricted. But tape works perfectly well for the tolerances you need and you achieved even better than necessary truing.
Gotit, thanks.  I will make some shaft collars when I have time to play with it.
« Reply #488 on: August 20, 2024, 05:55:32 AM »
Borrani going tubeless.  I used 3M 5200 glue to seal nipples in and it will get covered by special tape.
« Last Edit: August 20, 2024, 07:17:59 AM by 70CB750 »
« Reply #489 on: August 20, 2024, 07:18:30 AM »
Have you seen the “foam core” used on newer bicycles for spoked tires? It makes the tire tubeless, plus adds some amount of protection during tire compression. I don’t know whether they have any in 19/18” diameters, but the concept is pretty good.
I did not know that, will check it out.
« Reply #490 on: October 03, 2024, 06:19:20 AM »
From Suzuki for Honda  :)
« Reply #491 on: October 03, 2024, 07:23:57 AM »
Suzuda?!
Online Mark1976
« Reply #492 on: October 03, 2024, 07:45:40 AM »
Start with the end in mind...
« Reply #493 on: October 03, 2024, 07:46:52 AM »
Welding is so much art and science all rolled up
