Author Topic: 78 550 with Air assisted forks?  (Read 731 times)
Offline galensmitty
« on: May 01, 2011, 06:18:59 AM »
  So I have a 78 550k that I'm doing a cafe build on.  The forks are air assisted.  None of the  other 550s I've seen on the forum and interweb have this feature.  Could the forks possibly be from a 650 installed by a PO?  or was this an option with some of the later 550s?  Also, does the air assistance really improve handling that well, or should I just put some regular caps on the forks and be rid of the air assist all together?
Offline bikebitzofvt
Re: 78 550 with Air assisted forks?
« Reply #1 on: May 01, 2011, 07:31:37 AM »
Many models come with air fork caps from the factory and S&W, among others, made aftermarket caps.  IMO it was a cheap fix to make dampening rod forks "feel" better.  I have a Yamaha XT350 dual sport that needs 7+psi in the fork to handle correctly.
Part of the compression dampening of a fork is controlled by the amount of air above the oil, hence many fork oil specs are measured in mm from the top of the tube, not cc's.  As the fork compresses over a bump the oil is forced up in the leg, "squishing" the air above.  Oil can't be compressed, while the air can.  Adding air pressure - usually no more than 10 PSI - makes the fork compress more slowly, and adds some faster rebound.  It's usually a noticeable improvement.  Air should never be added with a compressor, only with a small pump designed for the application.
Perhaps someone can chime in with an appropriate PSI setting?
Those against air caps say the pressure causes seals to fail.  I find this to be highly unlikely and more likely caused by a mechanical reason or excessive pressure.
I hope this makes sense and helps!
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
