i spent about an hour running the syncho on the bike cant seem to get them all the same.. im runnig with a kerker 4-1 header exhaust and a stock airbox. i have the stock jets.. if im missing anything let me know.
-tom
You should be able to get them almost perfectly spot on. Follow these instructions I posted to a similar question:
http://forums.sohc4.net/index.php?topic=87117.0So you need to constantly adjust your idle screw (the large screw with spring on linkage) when you are doing the sync.. When you adjust them the idle will be directly effected. You MUST keep the idle between appr. 800-1300. Letting the idle get too high will negate the adjustments because your carbs will be operating outside of the idle circuit. Adjust one, wait a few seconds for the idle to differ, then adjust idle back up/down to range previously mentioned, then continue with syncing adjustments constantly bringing the idle speed into the appropriate range when necessary.
1. To continue from where you are now, I would go ahead and lean out your mixture screws first at 1/8 turns just until smoking stops.
2. set all nuts on the carbs where you were adjusting during the sync so that 2-3 threads of the screw are showing above the nut.
3. Adjust number #1 carb to #2. Make sure to adjust idle speed after back down/up
4. Adjust #4 carb to the same vacum as #3 carb. Adjust idle.
5. Adjust #3 to #2. Adjust idle.
Repeat sequence until they are all reading the same vacum. Adjusting in this sequence will keep you from going in circles since adjusting one will effect the others.
Once you have them synced you can fine tune your idle mixture (rich/lean)
Remeber, you must have valves in adjustment, cam chain tensioned and a clean air filter before you sync the carbs. It will do you no good to sync them if this hasnt been done FIRST.
Hope this helps
