Author Topic: CB500 Tachometer Block off Plug ??????  (Read 3006 times)
Offline Jt550
  • Is more then just a F-in
  • What have I gotten myself into...... Gotta Love It
« on: May 03, 2011, 12:53:52 PM »
Ive been beating this board & google for the last 2 hrs attempting to see if anybody makes or even knows of anyone that makes a Tach block off plug for a CB500/550 K...... Ive seen them for 750's, yet a no go on the 500's...
Any ideas... Any one have a milling machine at there disposal.?
Thanks
Tyler Durden: You're not your job. You're not how much money you have in the bank. You're not the car you drive. You're not the contents of your wallet. You're not your f*<king khakis. You're the all-singing, all-dancing crap of the world.
-78 CB550k with a BIG #$%* Eating Grin-
Offline kerryb
  • Not a very
Re: CB500 Tachometer Block off Plug ??????
« Reply #1 on: May 04, 2011, 07:28:38 PM »
I made one for my 750 so I could soda blast the engine while on an engine stand.  What do you want it for?
I can fill the hole with aluminum and an o-ring that the cross-screw will hold in place.  I'm not doing decoration work though.
I haven't seen what is available from other sources, got a picture?
just for fun...kerry
Offline MasterChief750
  • Detonation
« Reply #2 on: May 05, 2011, 06:04:36 AM »
is there thay much difference between the tach holes between the 750 and other bikes? besides ratios i would assume they all would use a similiar cable.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline kerryb
  • Not a very
« Reply #3 on: May 06, 2011, 07:27:15 AM »
I never checked, I'll try the plug on my 550 ('77).  Do they have different tach drive ratios?  My tach and speedo don't match on the 550 and I'd like to substitute some 750 units.
Offline SixGun
« Reply #4 on: May 06, 2011, 08:06:52 AM »
Are you getting rid of the tacho?
I just cut of the end of the tachowire (the little alu piece). Then i just found a bolt that was slightly bigger than the hole, and just screwed it in. Cheapest way to do it ;-)
Offline Roach
« Reply #5 on: May 06, 2011, 08:39:43 AM »
the 750 ones from joker fit.
1978 CB550K Cafe Racer
« Reply #6 on: May 06, 2011, 11:32:10 PM »
They are all the same, fit speedo drive holes as well. I made a bunch a while back (without a milling machine), still got some kicking around.
 If you need to contact me , email the address in my profile, I cant answer PM's on this board anymore..
Offline mrrch
« Reply #7 on: May 08, 2011, 06:17:26 PM »
Order PN 44835-365-671 from Honda,it is a speedo drive block off plug for a XR200. Works great,just need to trim the length to fit.
my build
« Reply #8 on: May 08, 2011, 09:07:32 PM »
 Yeah, that makes more sense, than to buy one off members here that make ones that fit..
 How much are the Honda ones BTW ?
