Author Topic: Post the photos of your dual disc set up  (Read 1369 times)
Offline Chicago550
  • 75 CB550
    • Gallery
« on: May 03, 2011, 02:24:37 PM »
I've been through the FAQ's and searched various threads on dual disc conversions but can't find many decent photos of setups for comparison. I would love to see more especially with close ups and would think that lots of folks on here would like to see what others have done.
« Last Edit: May 03, 2011, 09:22:18 PM by Chicago550 »
75 CB550
70 CB350 gone to new home
Offline mjstone
  • I'm definitly not a
Re: Show the photos of your dual disc set up
« Reply #1 on: May 03, 2011, 03:50:47 PM »
Here's mine. The bike is a '72 500, but the forks are off a '75 550, as is all of the additional brake parts and I,m using a master cylinder from a '77 GL1000.  The brake lines are braided SS lines made by pompadori with a double banjo bolt and 2 lower lines from the switch junction.  I'm also using the Speedo drive adapter from rangelov.  Both of these guys provide quality stuff, very much recommended.  rangelov also sells the adapter with longer bolts for mounting your two disks.  If he had been providing these when I bought my adapter from him I would have purchased them as well.  These pictures are from my post in the "What did you to your bike today?" thread on page 201, if I recall correctly. The originals are on a computer that is currently down so I can't give any better images than these right now.  If you look closely at the right side image you can see how I handled the shimming issue as well as the never addressed what to do about your fender brace issue.  You can see I also put the lock nut for the adjuster in between the fork tab and the spring.
« Last Edit: May 03, 2011, 03:55:08 PM by mjstone »
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Whaleman
« Reply #2 on: May 03, 2011, 06:14:34 PM »
My bike comes in for the winter. Dan
Offline Grabcon
« Reply #3 on: May 03, 2011, 07:24:49 PM »
Here are some recently completed CB750. I am using the standard master cylinder and it is just fine. I also had DOT Stainless Steel braided brake lines made locally by a company called Pirtek. Also is a link to photobucket. There several in progress photos that show the fit up, the speedo, etc.
http://s1143.photobucket.com/albums/n636/grabcon/
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline Willy D
Re: Post the photos of your dual disc set up
« Reply #4 on: May 11, 2011, 07:54:46 PM »
Here's pictures of mine. since i had the forks out anyway, i turned them around to the back. I had to grind the lower boss on the fork that did not have a brake mounted to it before and tap the hole. The caliper and pads wouldn't line up right with out doing this. I think honda left this in an unfinished state on purpose.  I used all stock parts with a double banjo bolt. The hard lines at the bottom are the stock lines, i just cut them off bent them to fit and re-flared the ends. The braided lines are from Slingshot cycles.
Offline pablo78cb550
  • mmmph.
« Reply #5 on: May 11, 2011, 08:35:27 PM »
best one i've seen uses a suzuki twin rotor set up.
« Last Edit: May 11, 2011, 08:37:49 PM by pablo78cb550 »
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
