I can't speak for the '75 model, but for my '73 it was a spot-on match. The KeiHin number on the needle was exactly the same (these are all KeiHin parts in Honda packaging). According to the carb spec charts, the carbs from '69-'76 models are all inclusive (same internals), so I'm pretty sure these would be considered the stock replacements (someone please correct me if I'm wrong!) and you should be fine. If you get the kits and want to be absolutely sure, compare the numbers from the needles out of your bike (if you're sure they are the stock ones) with those on the needles in the kit before you open them. This way, if they don't match, you can return them. Each kit services one carb, so you'll obviously need 4 sets. It's a bit of a bite in the wallet, but it will save you plenty of headaches in the long run...
