Author Topic: Which fuel octane should I use?  (Read 4530 times)
Offline dylboss
« on: May 03, 2011, 06:39:50 PM »
I did a search on this, but got many different results.  I have a '78 CB550, and wondering if I can use 87 or need to use 93 octane for this particular engine.  Sorry if this is a redundant post.
Thanks.
Current
- 1972 CB750 K2 - Brier Brown Metallic
- 1973 CB750 K3 - Flake Sunrise Orange
- 1974 CB750 K4 - Flake Sunrise Orange
- 1976 CB750 K6 - Candy Antares Red
Previous
- 1978 Honda CB550K
- 1972 Honda CL350 Scrambler
- 1972 Honda CB450
- 1998 Suzuki TL1000R
- 1993 Yamaha FZR 600
Offline CBGhia
Re: Which fuel octane should I use?
« Reply #1 on: May 03, 2011, 06:49:48 PM »
I use 87.  Really, you want to use the lowest octane you can without causing pinging.
« Reply #2 on: May 03, 2011, 06:51:02 PM »
The stock engine only needs regular gas, without alcohol if available.
Offline dylboss
« Reply #3 on: May 03, 2011, 06:52:15 PM »
Is there a benefit to using 93?  Smoother, or whatever?
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline CBGhia
« Reply #4 on: May 03, 2011, 06:58:00 PM »
No benefit.  It can actually cause extra carbon deposits.
« Reply #5 on: May 03, 2011, 09:46:35 PM »
No.
Octane has nothing to do with energy content.  Just the point at which it tends to spontaneously combust.
Most of the benefits are profits the seller makes.
Some machines need a higher octane.  The stock SOHC4 engine doesn't.
