Author Topic: replace rectifier cheap  (Read 7064 times)
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
« on: May 05, 2011, 07:46:12 PM »
wind generator diodes work perfect in bikes for less than 20 bucks off ebay
« Last Edit: June 12, 2011, 08:08:22 AM by skamagedon »
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline skamagedon
Re: replace diode trio cheap
« Reply #1 on: May 16, 2011, 08:32:10 AM »
Offline devaroux
« Reply #2 on: May 18, 2011, 07:48:53 AM »
How long have you been running this?!
Offline skamagedon
« Reply #3 on: May 18, 2011, 10:20:24 AM »
since 50 degrees outside in WI.....2 months. It works perfect, doesn't get too hot, works well with my 76' F150 regulator.
13.8 on my voltage readout @5000rpm
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
Re: replace rectifier cheap
« Reply #4 on: September 10, 2011, 08:58:01 PM »
Nice ! One question, I can't tell by the picture, where is the Red wire hooked to?   Thanks,   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
Offline Untold
« Reply #5 on: March 18, 2012, 09:36:39 AM »
Could someone break down how to hook this up? Assume I'm an idiot. Thanks
1976 CB550K
Offline verslagen1
« Reply #6 on: March 18, 2012, 09:42:31 AM »
yeah... assume he's an idiot   ;D
'88 Savage Daily rider
'72 CB500 Garage find
Offline Untold
« Reply #7 on: March 18, 2012, 09:58:00 AM »
Ha.  I meant besides the obvious.  Namely, looking for the answer to the question above about the red wire.
1976 CB550K
Offline CycleRanger
  • No comment about being an
« Reply #8 on: March 18, 2012, 11:01:17 AM »
This thread: http://forums.sohc4.net/index.php?topic=12465.0
contains very much advice about cheaper alternatives for replacing the regulator and rectifier.
Offline Untold
« Reply #9 on: March 19, 2012, 12:18:08 PM »
Thanks.  Did some more reading and looked at some wiring diagrams, and realized that was a dumber question than I thought it was. Oh well.
1976 CB550K
