well where to start.......
so i got back after taking off all my carb sync i forgot to tighten down the nuts.... well i re did everything and tightened the bolts.
then i put on my new clip ons off fleabay for $65 and sold my old ones because they werent long enough and the MC crashed into the top of the triple tree. i wanted to use the old stock one instead of upgrading to a modern plastic one... gross
then after all the electrical everything is on point.
back to my tail lights i decided to wrap the yellow led strip around my bullet tail lights. the hot glue gun thing didnt work so instead i zip tied them and it turned out great!! u cant even tell they are zip tied
(no idea why the picture is smokey...)
then after that
adjusted the rear axle with the right 3/4 of an inch slack on the chain
i adjusted the rear brake and pedal
adjusted the front caliper
in the short process of fine tuning my throttle cables
connected the fuel tank to the carbs (decided not to use inline fuel filters because i cant figure out how to route the lines without kinking) the petcock filter is mint so it should be no problem and the tank is clean
changed the oil again and decided going with a sae 20w-50 its hot outside!! but i will change it back to 10w-40 when it gets cold.
i also changed out the rear tire with the right tire on the right rim this time and got both my rims re balanced
then tomorrow morning im going to the DMV to title my new frame with a statement of facts and a bunch of pictures. so i hope i get it
then insurance and im set for the real road.
other than that my bike is
DONE DONE DONE after 1 year 2 months!!!
***************************************************** THANK YOU ********************************************************
i just want to let everyone and anyone who has commented and helped me out on these forums i do greatly greatly appreciate ur help and patience with me.
i love SOHC4 forums.
thank you everyone!!
****************************************************** THANK YOU *******************************************************so heres some quick pics i will take more tomorrow out in the sun
