If I understand correctly, in a stock configuration, the CB750s use an electromagnet design for the alternator. I think this means that if I don't power up the electromagnet, the three coils in the alternator won't produce any current, and I can run the bike solely off of the battery for a short time with the alternator coils unplugged. Is this correct?
The key to this setup would be simply removing the regulator (and, for safety, the rectifier) from the wiring harness. Based on the factory diagram for the F3 (what I own), this should let me perform my short test. Naturally the battery would go right back on the tender after the test =)
Will this work, or have I missed something? I don't want stray current coming out of those 3 yellow leads and arcing to the frame.
