Author Topic: CB125s "Big Blue" is UN-DONE!  (Read 117243 times)
Offline Flying J
Re: CB125s "Big Blue" is DONE!
« Reply #175 on: March 18, 2013, 03:10:11 PM »
man if that would fit....this bike would be scary fun to ride
« Reply #176 on: March 18, 2013, 04:01:41 PM »
Anything can be made to fit.... ;D ;)
« Reply #177 on: March 18, 2013, 04:02:19 PM »
Until you needed to turn or brake...
« Reply #178 on: March 18, 2013, 04:04:10 PM »
It would turn, but brakes would be an entirely different thing, those brakes anyway.... :o
Offline Flying J
« Reply #179 on: March 19, 2013, 04:40:28 PM »
I have a 3mm over bore piston for this bike that i want to use but i dont have a head gasket for it. Anybody know where to get one?
Offline Flying J
« Reply #180 on: March 23, 2013, 04:58:37 PM »
Found a oversized gasket after talking with the people at cometic. Ill order a new one on monday. Did some painting and had the valves done.
« Reply #181 on: March 23, 2013, 05:58:18 PM »
Is that another head? Or how are you going to salvage that one with cam and journals chewed up?
Offline Flying J
« Reply #182 on: March 23, 2013, 08:52:29 PM »
I found this one local. Had to buy a whole parts motor to get it. Now i have enough parts to build a second engine minus the head and cam.
Offline Flying J
Re: CB125s "Big Blue" is UN-DONE!
« Reply #183 on: April 11, 2013, 11:17:32 PM »
Cylinder should be done tomorrow. Going big bore up from a 122 to a 135. New cam chain and guides.
Offline Flying J
« Reply #184 on: April 23, 2013, 10:37:08 AM »
Just for my own records the carb is set up with a 110 main, 38 pilot and the needle moved up 1 notch. I could not get the thing to run on the idle circuit despite  my best attemps at cleaning the carb so swapped everything onto a different body and the bike runs great now. Still a little sputter a WOT.
Offline Flying J
« Reply #185 on: April 23, 2013, 02:47:09 PM »
Back on the market if anybody is intersted
Offline hoodellyhoo
  • CB350F
« Reply #186 on: April 23, 2013, 07:41:02 PM »
Are you sure you aren't destined to be the permanent owner of this bike?  ;D
Offline Flying J
« Reply #187 on: April 23, 2013, 09:40:59 PM »
I sure hope not.
 :o
Offline Flying J
« Reply #188 on: April 26, 2013, 10:06:19 AM »
105 main,38 pilot and needle moved up one. WOT sputter is gone. idle mixture screw is in pretty far so i thin i could drop down one pilot but its running good right now.
Offline grcamna2
« Reply #189 on: May 07, 2013, 02:21:42 PM »
Just a good head and cam is all I need.
How about a whole XR350 engine.... ;D
ff,
Have you ever considered doing More work on the motor ?
 such as a stroker crank ?? I like the idea of more power in that  200 lb. cycle ! I once bought an SL125 motor & put it into my CB100 ! I installed a Powroll 135cc piston kit along w/ a 10cc stroker crank kit & a mild Powroll street camshaft which made it a Honda 145.I was very happy(at 19 yrs.old)w/ the difference in power !
« Last Edit: May 07, 2013, 02:28:37 PM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline Flying J
« Reply #190 on: May 07, 2013, 05:08:54 PM »
Powroll has disappeared. I did look at some of their stuff but to bring it up to a like 150 or so was over $1000. It would be much easier to drop in a Honda 185 motor. They fit with a small modification to the frame. Friend of mine was building one. Had the motor mocked up in the frame but lost interest and sold all the parts.
Offline grcamna2
« Reply #191 on: May 08, 2013, 01:35:05 PM »
That's too bad about Powroll..;I liked there way of getting more power out of little Honda singles. I'm interested in swapping a 185 motor into a CB125S..,do you know anything about what kind of mods are necessary ? I wonder how much you can bore an XL185 out ? or an XR200 possibly ?? I heard about the 185 swap from a member here about a year ago,I think it was from member Kirkn...
Offline robotman
    • www.buggyrobot.com
« Reply #192 on: May 09, 2013, 03:04:15 AM »
What size are the tires?
Could you get bigger ones to fit in the swing arm gap or are you at the max?
Offline grcamna2
« Reply #193 on: May 11, 2013, 12:01:57 PM »
bump  :)
Offline Flying J
« Reply #194 on: May 11, 2013, 02:33:02 PM »
Im sure you could fit wider tires but why would you? to make the bike slower?
« Reply #195 on: May 11, 2013, 02:36:18 PM »
 ;D ;D    sorry FFJ, couldn't help it... ;)
Offline Flying J
« Reply #196 on: May 11, 2013, 03:01:12 PM »
Right, it can be done but he did a little more then go on a forum and ask if he could fit a wider tire.  :D
« Reply #197 on: May 11, 2013, 03:41:40 PM »
 ;D ;D ;)
Offline grcamna2
« Reply #198 on: May 21, 2013, 02:21:31 PM »
ffJ,
     Where did you purchase your 3mm over piston ? Does it come in small oversizes after the initial 3mm ? or is it just the 3mm only ?
I want to purchase this CB125S and was considering a bit more displacement.They're a Nice bike  :)
Offline Flying J
« Reply #199 on: May 21, 2013, 04:58:02 PM »
Bought it on eBay. 3mm only. It's old stock.
