Author Topic: Photo Request Rear Brake Set Up CB750 K1  (Read 1810 times)
Offline inpassing
« on: May 14, 2011, 09:09:00 AM »
I'm looking for a photo of the rear brake set up on a K1. I have the exploded diagram:
But I would like to see a close up from the brake arm to the pedal. The PO had a Raask rear set that he snapped in half and I'm trying to see if I have the parts to put the original back together, and then figure out how to make everything fit.
Thanks!
MD
Re: Photo Request Rear Brake Set Up CB750 K1
« Reply #1 on: May 14, 2011, 09:57:27 AM »
I have an engineless frame outside: I'll try to remember to snap a shot of it for you later today, if someone else doesn't first.  :)
Offline inpassing
« Reply #2 on: May 14, 2011, 09:59:06 AM »
Thanks.
Offline Rookster
« Reply #3 on: May 14, 2011, 01:35:22 PM »
Rearsets, but you can still see the brake arm and how its supposed to be oriented.
Scott
