Author Topic: wiring harness of death.... need help....  (Read 12460 times)
Offline xsmooth69x
« on: May 15, 2011, 08:01:42 PM »
ok so now im sorting through all my wiring.......
anyways im using the website www.vintageconnections.com since they seem to have the cheapest parts from what i found. if theirs a better website please let me know.
i also know of oregon motorcycles but their prices are more
anyways i want to replace all my connectors on my wiring harness so this is what i have so far....
4mm bullet male and female 25 connectors
3.5mm "^" (this is for the turn signals) <----- 1975 cb550 uses this i guess
latching 8 pin M/F connector 6.3mm spaded connector
latching 6 pin "^"
latching 4 pin "^"
now this is what i cant find the last part.....
the middle 9 pin connector. i can not find this. i know its not a mini connector either. its a normal 6.3mm spaded latching connector.......
something to look at
this is the harness as a whole. the sticky note is the headlight
moving from the headlight and down to the back end where my previous owner thought he was an electrical engineer......
another....
close up of ^
moving along more
close up of ^
overall big pic of the last 2 main pics with close ups
last one all the way at the end
zoom out of that ^
some other pics
also i cant find this connector either
its a 1 - 4 connector, one wire goes in the middle then it can be split into 4 other connections
i dont really have to stick with period correct fitting either.... if theres a cheaper maybe even modern way to do all these connections im open to all suggestions
« Last Edit: May 15, 2011, 08:06:48 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline hesselfuzz
Re: wiring harness of death.... need help....
« Reply #1 on: May 15, 2011, 10:43:21 PM »
Try Vintage CB750 and/or Z1 Enterprises.
Ciao
Moderation is a fatal thing, the only success is in excess.  -Oscar Wilde
73 CB750k
78 CB750ss
70 CB750k
06 Buell Ulysses
Offline xsmooth69x
« Reply #2 on: May 15, 2011, 10:51:03 PM »
well i cant seem to find a wiring harness for a 75 honda cb550
i have found wiring harness for the cb750 but nada on the 550
unless there the same?.....
Offline xsmooth69x
« Reply #3 on: May 16, 2011, 12:37:05 AM »
Offline neverendingproject
  • Making the Northwest louder one road at a time
'75 CB550 K1 Cafe Project
'72 CB500 Japanese market
Offline bikebitzofvt
« Reply #5 on: May 16, 2011, 07:39:19 AM »
Those spots where the harness is spliced together are probably stock.
I like how the left hand connector in the 2nd to last picture looks - like it has cavities ...  yuck!!
I'd like to change over to metripack waterproof connectors on my 750 once I get to that stage, something like these:
http://www.casperselectronics.com/store2/product_info.php?products_id=686  the same starter kit can be found elsewhere for less $$, at Jegs, etc...
If you wanna stay with stock style connectors here's a post reply of mine from way back on the subject:
I have a set of crimpers from Radio Shack.  They need a anvil shape that pushes the tangs of the connector around and into the wire.  Connectors can be had from Suzuki fairly inexpensively, usually in packs of 50 for around $10.00/ pack.  Sockets are available, too - usually about $3.00 - $6.00 each.  The connectors are brass colored, not tin like OEM Honda.  Their bullet connectors aren't compatible with the OEM Honda ones, however so you'd have to change both sides...
Here's a short list of part numbers:
Male bullet: 09900-28701-001
Female bullet: 09900-28701-002
Male blade: 09900-28701-011
Female blade: 09900-28701-010
2 socket connector: 09900-28701-006 (for large blade connectors)
6 socket connector: 09900-28701-013 (For large blade connectors)
Actually, here's a link:
http://www.alpha-sports.com/tools/suzuki_tools.htm
1/16th down the page are all the connectors...  They also list weatherpacs but are pretty pricey...
As far as I know the vintage Honda bullet connectors are made of unobtanium.  If someone has a source for them I'd sure like to know!!
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
Offline CycleRanger
  • No comment about being an
« Reply #6 on: May 16, 2011, 08:12:52 AM »
http://www.oregonmotorcycleparts.com/connectors.html
Or
http://www.vintageconnections.com/
« Reply #7 on: May 16, 2011, 08:26:17 AM »
Or
Oooooh, I'm ordering some right now paypal even!!!!!!!!
Awesome!!!
Offline CycleRanger
« Reply #8 on: May 16, 2011, 08:42:08 AM »
Awesome!!!
Indeed, it is.  :)
I got stuff I ordered from Oregon Cycle in about two days!
Offline hyde7278
« Reply #9 on: May 16, 2011, 09:51:18 AM »
Most of the splices are definitly stock (same color going out as going in) if you undo the tape there prob sodered conections, I found this also when I had to rebuild mt electronics bracket and wiring after the battery was reversed by the PO. If you didnt buy the wire crimper from vintageconnections.com I would highly recomened them prob the best $35.00 I spent on the bike.
« Last Edit: May 16, 2011, 09:53:30 AM by hyde7278 »
78 CB550 (FOR PARTS)
76 CB550F
Offline xsmooth69x
« Reply #10 on: May 16, 2011, 02:24:49 PM »
well i found 2 places on the net that still have "supposedly" OEM NOS cb550k1 wiring harness.
im going to call them tomorrow to find out if its legit
32100-374-000 is the part # for the harness
www.cycledesignonline.com for $77.86
and
www.lakecityhonda.com for $77.86
found another one but it was for $120ish
both stores are only open tues-fri so i will call tomorrow to find out.
pricing out to repair my harness is more than $77
wire stripper
fitting crimper
shrink wrap
all the connectors
and my time.....  >:(
Offline xsmooth69x
« Reply #11 on: May 16, 2011, 02:25:45 PM »
Try this http://www.davidsilverspares.co.uk/CB550K1-1975-USA/part_70707/
ya i looked at this option but god its so expensive..... and its euro parts and shipping kills.....
Offline xsmooth69x
« Reply #12 on: May 16, 2011, 02:27:11 PM »
http://cgi.ebay.com/ebaymotors/74-75-HONDA-CB550-WIRING-WIRE-HARNESS-_W0QQcmdZViewItemQQhashZitem4aaad00d03QQitemZ320693341443QQptZMotorcyclesQ5fPartsQ5fAccessories
$70 buy-it-now.
ya if im going to buy a used harness i can always pull one myself from the bone yard (maybe in better condition) for less than that price.... for now im looking for a NOS one but if not im going to pull one
Offline xsmooth69x
« Reply #13 on: May 16, 2011, 02:29:35 PM »
wow sweet site thank you so much deff bookmarked that!!
and ya those darn moon connections made of unobtanium  >:(
Offline xsmooth69x
« Reply #14 on: May 16, 2011, 02:50:27 PM »
Yes, I agree.  New is better.
There are limited sources of used parts near me so it's nearly always ebay.
you have limited resources?!?! your in texas  :o nothing degradates other than sun damage.... im up here in MN and everything rusts away
Offline CycleRanger
« Reply #15 on: May 16, 2011, 03:40:18 PM »
Well, from where I am I pretty much have to go to San Antonio or Houston to find a motorcycle junk yard.
It's usually cheaper to just hit up ebay.
Offline xsmooth69x
« Reply #16 on: May 16, 2011, 03:59:55 PM »
ya tru that
Offline xsmooth69x
« Reply #17 on: May 17, 2011, 12:09:16 PM »
yup the interweb has no NOS cb550 wiring harnesses......
going to have to pull one from another bike....
Offline D.Luu
« Reply #18 on: July 30, 2011, 04:32:49 PM »
Sorry to barg in but I'm also in the process of rebuilding my '77 550k.
CycleRanger, what junkyards would you recommend in Houston, since that's where I live.
Offline CycleRanger
« Reply #19 on: July 30, 2011, 09:37:14 PM »
Sorry to barge in but I'm also in the process of rebuilding my '77 550k.
You might try http://www.houstoncyclesalvage.net/
Or http://www.necycle.com/
Or
http://www.houstonmotorcycleexchange.com/
Offline uptickk
« Reply #20 on: July 20, 2012, 06:03:53 AM »
Did you end up going with one of these outfits?  I am looking to replace the wiring harness as well on my 1975 CB550F.  Looks like the part # for the 550f is 32100-390-000.  Not sure if I should ebay it or bite the bullet and get a new one.
cycledesignonline for $77.86
and
lakecityhonda for $77.86
wire stripper
fitting crimper
shrink wrap
all the connectors
Online Don R
Offline AEngelsrud
    • engelsrud.com
« Reply #22 on: July 20, 2012, 09:09:32 AM »
So I was looking at www.vintageconnections.com and the Professional Kit CK-1 - $55.00 with the Crimping tool, sounds perfect.  However, when I look at their order form in more detail I notice that the connections that come with the kit are 4mm and state -  "Do NOT use for any models of Honda inline fours, from 1969 on. Order SB2, below".  The SB2 is a 3.5mm connection, but they do not have 3.5mm connections for ALL the various connection types that come in the kit - like the dual socket connection.
Anyone have any thoughts on the 4mm vs 3.5mm connection?
Thanks!
Aaron
bollingball
« Reply #23 on: July 20, 2012, 10:00:53 AM »
 If I reading your question correctly It does not matter which one you use as long as you change both sides. Male/female
Ken
Offline Brantley
  • Drano
« Reply #24 on: July 20, 2012, 01:36:41 PM »
wire stripper
fitting crimper
shrink wrap
all the connectors
and my time.....
Yes, but you will wind up with 2 tools you'll have forever and a harness you know is right... And I'd rather spend time working than standing in line at the post office than returning an incorrect (or inferior quality aftermarket) part.
I've used V.C. to rehab 2 harnesses so far. Good stuff. Super fast. Del actually takes a second to hand write "Thanks" on the invoices. You can use the 4mm connectors if you replace both male and female and don't forget if you replace the part that connects to the harness to replace that connector. I'd skip the kit and buy the individual 3.5mm parts you need. His block connectors are the same story (at least the 6.3mm ones I got)- you HAVE to replace both ends, as they do not meet the OE exactly.
And, yeah those look like the factory solder splices. Another option is to buy a junk harness with decent connectors and cut, splice, and solder. If you can't find the 4-1 connector, just solder in another like color wire and use two 2-1, etc.
« Last Edit: July 20, 2012, 01:44:57 PM by Brantley »
