Author Topic: Carb Size for K&N pod Air Filters  (Read 4202 times)
Offline hondachopproject
« on: May 03, 2005, 12:29:17 AM »
Hello,
Looking to add  K&N pod Air Filters to my 76 cb550...but not sure proper carb size. Have seen 35mm listed on one site K&N site states 40mm???????
Part listed was RC-0844.
Any help appreciated,
Thanks,
Lee
« Last Edit: May 03, 2005, 12:34:27 AM by hondachopproject »
92 HERITAGE
Offline cben750f0
Re: Carb Size for K&N pod Air Filters
« Reply #1 on: May 03, 2005, 07:21:16 AM »
mate measure the outside of the carb neck to get exact size, then just find a set that will fit that neck size... you will have to take the air box off, but most aftermarket mobs, have a selection of filters, just ask them if they have a pod to suit XYZ size carb neck...peace
Bobby
« Reply #2 on: May 03, 2005, 07:35:01 AM »
Lee, I have a set of 42mm pods on my '78 carbs and a set of 39mm's on my '76 carbs that I purchased from PartsnMore.com at https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=carb
That being said, since they are "rubber" and attach with a hose clamp, I can squeeze the 39mm's onto my '78 carbs and crank down the 42mm's onto my '76 carbs.
-Bobby
Offline cben750f0
« Reply #3 on: May 03, 2005, 07:43:10 AM »
also just found these on ebay... they arent k&n though  http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4546026184&category=35595  peace
Offline mgilvary
« Reply #4 on: May 03, 2005, 08:45:12 AM »
I bought pod filters from cycle-recycle (http://www.crc2onlinecatalog.com/Index_Main_Frame.htm) for my 75 550. They are 35mm. They fit perfectly on the carb body, and they also fit snugly within the frame.
Offline Warlock
Ride On...
Offline mcpuffett
« Reply #6 on: May 03, 2005, 02:41:08 PM »
hi, i just bought some of those filters that cben f1 was showing  :)39mm  to fit a 76 f1  mick.
qcextreme
« Reply #7 on: May 04, 2005, 12:10:52 PM »
I have a 74 CB350F if i run air pods will I need to rejet? If so what size jetting??
Offline mcpuffett
« Reply #8 on: May 04, 2005, 02:44:35 PM »
yep you will have to rejet but don't know what size? but someone on here will know  ;) mick.
Offline cben750f0
« Reply #9 on: May 04, 2005, 05:31:47 PM »
put the ilters on ,a nd go for a ride, do a plug chop....if they are lean go up a jet size and check again, if its ok leave it...peace
