Since you asked; for what it's worth........
The chain on my CB750 K4 gives me the biggest pain in the *** , more than anything else that ever needs to be done on my bike. I have only 24,500 miles on the bike.
My understanding is that the manuals say adjustment is needed every 500 miles. It seems like I need to do mine about once every two weeks, though I sometimes put it off for a month or so. I normally ride 10 to 15 miles per day, ergo, about 280 to 420 miles a month. It is the original chain.
I have tried many different brands of "modern" spray on lubricants, letting them soak in while the chain was warm from a ride, then cleaning off the excess so it doesn't get thrown all over the rear wheel. They all throw excess on the rear rim, no matter what the spray can says about not flying off.
About one week ago I switched from the spray on wonders to old fashioned 80/90 weight gear oil. I put it on after cleaning the chain, let it soak in, then with a rag took off the excess to help prevent it flying all over the rim. So far, after proper adjustment, the chain has stayed better than it ever has before. It is more "pliant", non kinking, and hasn't needed adjusting yet, though it has only been a week or so (sometimes I had to adjust in less than a week with the spray on wonders).
Though time will truly tell, so far I am happier with the gear oil than the sprays. The gear oil seems to really lubricate the chain and penetrate to the innards of the chain. I felt that the spray ons never really did that, they simply dripped off the links, appearing to soak between the links and onto the pins and rollers, but only an appearance, not for real.
I do know that the chain, with use of the gear oil, has gotten rid of the somewhat tight spots it did have.............
P.S.~~~I thought I should add that before I changed to the gear oil, I did thoroughly clean the chain in a pan that was placed under the bike with the rear wheel removed and filled with denatured alcohol. I scrubbed the chain with a wire brush and the alcohol. Then I let it dry completely using a hair dryer to evaporate the alcohol. At this point I added the gear oil.
~ ~ ~ jaknight ~ ~ ~
