Author Topic: Hesitation at low RPMS and Plug reading cb750k with pic  (Read 7608 times)
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
Re: Hesitation at low RPMS and Plug reading cb750k with pic
« Reply #25 on: May 25, 2011, 05:26:09 AM »
My #3 float was "heavy"ie = "gas filled a bit" and this affected my mid throttle hesitation. Put a new needle valve and float on it, new #3 plug and the bike purrs like it's brand new again!
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline ntm1974
« Reply #26 on: May 25, 2011, 05:10:27 PM »
A couple of guys have PM'd me with a similar problem so here is an update:
All my spark plug cap covers were out of spec.  I replaced all the caps and WOW what a difference!  I'm sure the earlier carb work contributed as well.  The bike feels much smoother off the throttle and my plug readings seem to have stabilized.
Other lesson learned: I am thinking that I probably had a float that wasn't as buoyant as the other floats.  I'll probably replace them in the future but in the meantime I think that when dealing with unknown floats and float jets, it makes a lot of sense to use a stack to set the float levels.  Mine were all set to 26mm and #4 showed way lower in the stack.  After setting them using the stack, it worked alot better.
Thanks for the replies guys.  This forum is a sanity saver.  Now onto setting up the rest of the carb circuits!
