Author Topic: sprockets  (Read 1203 times)
motopsycho1965
sprockets
« on: April 19, 2006, 03:41:39 PM »
Does anyone know will the rear sprocket from a 1978 750K fit a 1978 750F.  Want to change my gearing a bit. Any help will be appreciated.
Offline 78 k550
Re: sprockets
« Reply #1 on: April 19, 2006, 04:55:49 PM »
Do you own both these bikes? If so I would take some time and match them up. I have swapped 500/550 hubs and sprockets no problem. I bet a paycheck they swap.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Clyde
Re: sprockets
« Reply #2 on: April 19, 2006, 05:13:23 PM »
I believe a 78F uses a 630 chain and has a different final ratio.
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline eurban
Re: sprockets
« Reply #3 on: April 19, 2006, 06:32:04 PM »
Both the 78ks and Fs use a 630 chain.  I do believe that you can swap sprockets between the two but I am not 100% sure.  Keep in mind that used sprockets are a gamble and if you were actually ordering up a new set that you could simply go to sprocket specialist's website and order a rear sprocket in the number of teeth that you desire.  They would likely have the stock specs on their site.  Good luck.
motopsycho1965
Re: sprockets
« Reply #4 on: April 19, 2006, 06:37:20 PM »
No, I don't have both bikes, the K has the ratio(15 tooth front - 41 tooth rear) that I want to try on my F for fewer RPM on the hi-way.  I am purchasing new sprockets over the internet and want to be sure so I don't have to return them if they are wrong is all.  Thanks for the input.
