Author Topic: help 2-3 not firing on the side of the road  (Read 806 times)
Offline MasterChief750
  • Detonation
« on: May 19, 2011, 02:40:43 PM »
Ok Popwood and I are at a gas station trying to figure out why his 2-3 is not firing. He said its been going in and out. When points are closed no voltage like it should be but when its open we read like .3 of a volt. Have verified connections are good its not the condensor. Help!!!
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
bollingball
Re: help 2-3 not firing on the side of the road
« Reply #1 on: May 19, 2011, 02:56:13 PM »
750? doesn"t the same blk/w wire feed both coils under the tank?you must have power there if the other one is firing. look where they branch off at the coils
KingCustomCycles.com
« Reply #2 on: May 19, 2011, 03:03:13 PM »
there is a Y connector under the tank, black wire in, two black wires out.  Check the connector, they get loose, corroded.
  • Detonation
« Reply #3 on: May 19, 2011, 03:52:45 PM »
ya got it workin again but that was enuf for him to turn back he doesnt want it doing it the rest of the trip then he has to find a way home.
I AM THE STIG
Sam is THE STIG
bollingball
« Reply #4 on: May 19, 2011, 04:02:39 PM »
Glad you got it. What did you find?
