First off, thank you, everyone, for the many postings that helped me through my first complete disassembly, cleaning and rebuilding of the carbs on my CB550F. I thought it all went extremely well, until I peered into the intakes. The #3 throttle valve is way out of sync from the other 3 throttles. For example, when the throttles are all closed, the #3 throttle valve is roughly 20% open and cannot be adjusted to a more closed position (the screw is at the stop).
I was running out of time after I got it reassembled (had to go to work) but I removed the cover and poked around and it looks like everything was reassembled exactly the same as the other carbs. I'm hoping that I did something wrong that I haven't spotted yet, and that I can easily fix it, however, I suspect that it may have been this way already. I’m going to dig into to it further tomorrow. I just recently got the bike and I never really had a good look at where the valves sat relative to one another before I took it apart. I fear that the horizontal arm running thought the head of the carb, that the throttle link arm bolts onto, is the wrong part. Could it be meant for carb #2 or #4, and was installed upside down to work with carb #3?
I have the following questions:
1) Is there any other way to adjust the individual throttle valve position other than the adjusting screw on the adjuster holder? You can't adjust the position with the bolt on the throttle shaft, can you?
2) There isn't any reason that the #3 throttle valve is supposed to be more open than the others?
3) If this is how it was in the first place, how hard on the engine is it to have one carb that far out of sync?
I was thinking I could test my theory that the arm I mentioned before is the wrong part, by switching it with the #1 carb’s arm, and see if the problem moves to carb #1, but I thought I’d see if anyone has any insights before I start tearing the thing apart again.
