Author Topic: F2 cafe - relocating electrics  (Read 712 times)
Offline dakota
« on: May 23, 2011, 02:02:51 AM »
Hi all,
I am trying to relacting the electrics on the bike because I am building a caferacer.
I have put the battery in the middle of the frame next to the new oil tank, all the other electric parts are going under the seat.
The problem I have is that I don't know where to put the starter solenoid. Can I also put it under the seat? Than I have to put longer cables between the battery and the starter.  Is this possible or must the solenoid be with the battery as close as possible?
regards,
gp
bollingball
Re: F2 cafe - relocating electrics
« Reply #1 on: May 23, 2011, 03:29:55 AM »
You can put it any where you want. Don't go down in wire size. Usually the longer the run you need to increase the wire size I don't think the bike is long enough for this to be a concern.
