Author Topic: straight trough exaust /carb rejet  (Read 637 times)
Offline frank
« on: May 23, 2011, 09:03:40 AM »
I have rebuilt motor (new cam, main bearings , valves , gaskets, seals ect.. ) on 1982 cb650 sohc , rebuilt the carbs with stock carb kits after sonic cleaning and have put on a set of straight through slip on mufflers now wondering if I have to rejet carb? runs excellent at idle but crapy after that, have tryed adjusting idle adjustment screw but no luck any info would be welcomed thanks
Offline splitt
Re: straight trough exaust /carb rejet
« Reply #1 on: May 23, 2011, 07:21:11 PM »
Think of an engine as an over glorified air pump with a carburetor. Any change that that increases or decreases the flow of air changes the fuel mixture. The majority of the time, you will have to rejet.
« Reply #2 on: May 23, 2011, 07:50:09 PM »
Splitt is right, if you have more going out the back you need more going in the front.
