Author Topic: '78 CN750F Carbs  (Read 512 times)
Offline SurfinBird
'78 CN750F Carbs
« on: May 23, 2011, 12:52:07 PM »
How are these carbs different from others? When I removed them to clean I noticed a lack of diaphragms on  the individual carbs. I did see the accelerator pump assembly on the #2 carb. Can someone explain how they are different? Also the stem of the pump was slightly bent, not bad more like a kink, the stem is still functional and engages with the throttle when opened. Should I replace it, i've checked a few places and no one has them.
Thanks
