Author Topic: Cheap 836 kits back on ebay...$110! *Update!  (Read 112225 times)
Offline KJ790
Re: Cheap 836 kits back on ebay...$110! *Update!
« Reply #200 on: December 11, 2011, 09:50:03 PM »
Dude, you have some serious comprehension problems, that was in context to using a F2 head on a K model block.... :o  And if you were as smart as you are trying to make out you would know that....
Who said anything about running an F2 head on a K block? This discussion is about using pistons designed for a K head with an F2-F3 head. I said that lots of people are currently doing it and you said that they modified the head so it wouldn't leak oil...
Instead of being completely argumentative, why not address what i was saying, Why should someone go to all the trouble of doing the things that you do with those cheap pistons, to make them work in a "F" model engine when, for close to the same amount of money and with less time and screwing around, just use the parts that are meant for the F bike. Now if you can stop taking everything out of context and turning this all to #$%*, see if you can give me a straight forward answer....
Sigh...
An 836 kit with stock compression will still make significant power over stock, even without touching anything else on the head. By simply putting these pistons in and slapping it together you will see 90% of the gains that you would with the 10.25:1 compression pistons. Basically instead of seeing a 10hp gain you will see a 9hp gain but save $250.
The reason I use these is to save money, as I said from the start.
So as I have said from the start, if you are trying to build the fastest engine possible then obviously go with the higher compression pistons. However, if you are trying to get more power on a budget then these ebay pistons are nice since they will save you over $250 and give you 9/10 of the power gain of the higher compression pistons.
I don't know how many times I can say it, but let me try one more time... It takes me no more time or effort to fit these pistons than any others. I measure up every engine I build, regardless of the pistons used. In the end this set up is significantly cheaper for me.
Offline dragracer
  • CB750F Dragbike
« Reply #201 on: December 12, 2011, 09:24:22 AM »
Guys, the original poster was only letting the members know the pistons were once again available on Ebay. He asked if anyone had used them and could give a report. Now we've gotten into bickering over certain combinations and crossed the line with personal attacks. Should we let any subject push us over the edge of being civil towards each other???????????? Can we not simply disagree and then move on. Instead of  turning this into page after page of debating specific applications??? We all have our opinions, whats wrong with respecting another persons right to voice theirs even if we don't think its correct.
In the infamous words of Rodney King; Can't we all just get along!!!
Offline jaguar
« Reply #202 on: December 12, 2011, 10:56:56 AM »
^^+1
anyone actually run and engine with these yet?
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #203 on: December 12, 2011, 11:26:32 AM »
^^+1
Good question.  :-) ........... I will use them as the need arises on my builds because they are a good value.   The only real issue is the dissemination of false information being a problem for present and future research.  Other than that, I could give a fuk about the jerks on this board that want to argue more than help.
« Reply #204 on: December 12, 2011, 11:41:05 AM »
^^+1
4 so far, all work fine. Adds significant torque, and make less heat than the Wiseco pistons. Do get the HD studs from Big Jay (or the same ones from Z1 Enterprises) if you go this route, to reduce tendency toward oil leaks at the base gasket and head gasket in the future.
mrjack55
« Reply #205 on: December 12, 2011, 11:53:38 AM »
^^+1
Well I think that about sums it up.  ;D
« Reply #206 on: December 12, 2011, 11:56:36 AM »
^^+1
Hondaman do you want to wade in once with an opinion on these pistons once and for all in an F2-F3 application so maybe it can be put into the record and maybe to bed also ??
Offline jaguar
« Reply #207 on: December 12, 2011, 12:00:27 PM »
thought that the k piston in F motors thing has been talked about....a million times
those motors need different pistons from K motors.
Will they work?  eh im sure they will run but well?  dont think so
there are options for good F pistons.
yes not at $100 but still.
maybe the focus should be on getting the builder of these $100 K pistons some F pistons to use to make a cheap F kit so the F guys stop with all this....
Offline fatmatt650
  • Part Deux
« Reply #208 on: December 12, 2011, 12:12:30 PM »
^^+1
Yes, while the issues has been "discussed" quite a bit  we still have no definitive answer. The whole point to using these pistons in the f2/3 - I'll say it again - is to keep compression stock while boosting displacement. Also there seems to be some benefit to the flat topped piston increasing airflow.
« Last Edit: December 12, 2011, 12:24:10 PM by fatmatt650 »
Offline dragracer
  • CB750F Dragbike
« Reply #209 on: December 12, 2011, 01:03:08 PM »
I think you just nailed the whole off topic discussion. I doubt it would be a significant increase in cost to account for the F design when casting F model specific pistons.
Maybe those in debate can push this request through- it seems that time would be better spent in helping the community as a whole.
Offline jaguar
« Reply #210 on: December 12, 2011, 01:46:26 PM »
i generally think about things like this
-honda paid alot of very smart people alot of money to build these things and when they say that parts only fit X then that should tell you something
its true that some times you can take parts from one thing and put them on something else and it works great Ex the dohc twin piston calipers bolt on to a F2/3...thats great!
also since we are talking about bikes have have been around for years most everything has been tried so if it worked people would have tried it and kept doing it....
I dont think those pistons will keep even the stock CR in a F2/3
« Reply #211 on: December 12, 2011, 04:18:56 PM »
^^+1
Hypocrite.....  You only jump in to be an arsehole, and once again you have succeeded. I see you are swearing now, after trying to get Terry kicked for exactly the same thing {misspelling swear words to beat the censors} in your "Blasphemy" thread. What a total clown you are....And what a poster boy for religion you are... ::) What have you added here.?  I am not the only one with this opinion about F2 F3 engines and K pistons , its been covered 100's of times.
You see, thats what i have been told {recently by some very competent people} and read over and over again on here and i had no problem discussing it with 790, there were some assumptions and misinterpretations {on both sides}of some things said here, but  its only when the circus arrived it all went to #$%*.... I wouldn't think being a complete dick has added anything relevant to the discussion at all but it was expected.....Well done Rigid... You can change your name but you can't change your spots.... ;D ;D ::)  It also seems like there are a few thin skinned people here that think anytime anyone questions something, they call it an argument. 6 or 7 posts in a thread seems to constitute an argument when in real life, it's only a short conversation and is also an easier way to discuss things, all emotions are present and not assumed or contrived, i suggest that some people learn to debate without resorting to calling everything an argument just to justify their point of view. I love a good discussion but a lot of the time it all goes to #$%*.... ::)
Jaguar, i couldn't agree more, I have never been that good at getting a point across through a keyboard.... ;)
« Reply #212 on: December 12, 2011, 04:50:21 PM »
^^+1
Well, maybe....I don't think I'm anyone's "final authority" when various opinions pop up. :D
The 836 pistons are what I call 90%-ers. By this, I mean they need a little TLC in the finishing department because of some flash and rough edges here and there, and sometimes some weight-balancing work (if you are as picky as I am). The oiling holes on them should all be hand-chamfered a bit, as they are drilled, but not fully finished like ART pistons. And, most of the rings must be hand-filed on these pistons, as they are about 0.5mm too big. I've got a post around here somewhere about all this, when Z1 Enterprises first introduced the 0.5mm and 1.00mm oversized ones from this same Thailand vendor: the ones from Z1 are better-finished, with fitted rings, and look like "completed" versions of the ones sold by CycleX as "Bobber or chopper" pistons (which resemble these 836 versions in roughness). I've had some discussion with Z1 as to whether they might venture into providing the 836 versions in a more finished style, but nothing is settled over it, at least not yet: they didn't sell many of the oversized ones this last year and have lots of CB750 inventory on hand as the result.
I've heard all sorts of chamber volume numbers here and there, which hasn't helped the discussion: the stock K0-K6 heads are 22.5cc or so, which yields a final static compression ratio of [9x((836/4)+22.5)/(836/4)]=9.97:1, all else being equal on a K0-K6 engine. This leaves lots of room to add a quench band (about 0.7cc extra) and trim back the swirl shrouds (perhaps another 0.3cc) and still have more CR than you started with. Typically, the measured compression on one of these 836 engines after break-in is around 140 PSI, while the Wiseco (10.25:1 advertised) versions make about 155 PSI.
Part of the published compression ratio of the "F" engines is not from static compression, but from delayed cam timing (5 degrees later than K0-K6). In the various versions of the F0/F1/K7/K8 heads I've been working lately, the chambers are a hair over 23cc, stock. Those engines' pistons domes are approximately 0.7cc in volume, which would resemble more a K0-K6 engine with a 0.008" milled head than anything else. The delayed cam adds a dynamic compression increase at engine speeds above where the incoming charge can force its way in against the exhaust pressures during overlap, which gives those later bikes that "rush" feeling at 6000+ RPM (that's about when the cam starts getting effective).
The F2/3 engines are the 'special case', where the larger chamber volume comes from the bigger valve(s) being squeezed in. Honda wasp-waisted the chamber a little to try to keep this volume down, but in some ways it wasn't enough for even the stock engine to work as they had probably hoped: it meant they had to remove most of the swirl-charge ridges to prevent an incoming air dam below 5000 RPM that would have made the engine fall more flat than it does (in the F0/F1) at those speeds. The K7/8 solved this by using smaller valves.
So, all of that said: I have an untouched F2 head sitting on the floor in my room, will measure the chamber volume this week to see how these flat-domed 836 pistons would work out in CR. This was planned anyway, for the upcoming book on CB750 Performance, which is to be the hotrod supplement to my first text. So far, I have only put Honda pistons in these F2/3 engines in the past, simply because they don't often show up in my stable for performance work. In the last 3 years, I've done more K7 engines than anything else, oddly enough.
My personal philosophy is to make HP with flow, not extra compression that isn't strictly needed (in other words, I like to make touring bikes). The extra CR always adds heat up high in the engine: while the 750 cools (overcools) exceptionally well in this regard, the heat is responsible for the shorter valve guide life in the later engines (along with their crummy guide materials). Compression does not return as much HP as flow: for a 10% CR increase you might get 3% more HP with hotter heads, but for a 10% flow increase you will get nearly 10% more HP, with cooler heads and cylinders. More displacement moves this heat downward, into the cylinders, so it is managed differently overall. These things all matter together, in the end. ;)
« Reply #213 on: December 12, 2011, 07:23:57 PM »
I'm planning on using this kit on my 1977 CB750F2. The bike is used primarily for loaded (sport) touring and has taller than stock gearing. Mileage is about 26,000. I also plan on having the head rebuilt. I hope to increase torque without diminishing fuel efficiency. Will this "flat topped" piston be appropriate for my "domed" F2 head? Does anyone have any other recommendations about building a touring motor? Cam selection? MPG improvements? Other mods?
Matt, with only 26K miles, you might consider leaving the bore stock, and just have the head work done.
Offline longshanks
« Reply #214 on: December 13, 2011, 12:15:51 PM »
^^+1
Do the HP figures change much or just torque?
cb450 K5
« Reply #215 on: December 13, 2011, 02:18:57 PM »
^^+1
HP=torque*RPM/5252 ;)
Offline fatmatt650
  • Part Deux
« Reply #216 on: December 13, 2011, 02:28:59 PM »
That would probably be the best bet for my stated intentions for this motor however I'm just kind of obsessed w/ going a little bit further w/ it, power wise. I'm actually buying another motor w/ 23k miles on it off CL to do this build on so if I'm not happy w/ the results I can always try again w/ my original motor.
My SRX600 is bored  a mere 25cc bigger and has higher compression and extensive headwork done and it shows DOUBLE stock horsepower on the dyno so I realize the advantages that can be attained from increasing flow.
HondaMan - Thanks for all the info, that's quite a bit of excellent information to digest. I'm looking forward to seeing those chamber volume numbers.
« Last Edit: December 13, 2011, 02:58:15 PM by fatmatt650 »
Offline Grnrngr
« Reply #217 on: December 13, 2011, 06:07:46 PM »
So Hondaman..are you using the head gasket that came with it too?  how about the "cheap complete gasket set"?
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
« Reply #218 on: December 14, 2011, 03:27:38 AM »
Don't expect much out of just adding this 836 kit Matt, my gold K2 with F2 engine fitted with the "correct" Wiseco 836 kit didn't really feel any more powerful than my stock K0, so unless you're gonna get some headwork done, and a better cam (in which case you'd pony up the dough for a more appropriate big bore kit anyway) you're probably just wasting your time.
Someone asked earlier if you can use F2 pistons in a K engine and the simple answer is yes you probably can, but from personal experience I wouldn't recommend it at all, here's a pic of my experiment using an F2 engine with K6 head and cylinder block, but using F2 pistons and F2 cam.
The engine ran for approx 30 seconds before I realised what was making all that racket and switched it off. It never revved over 1000 RPM, but the exhaust valves smacked dents 1mm deep into the crowns of the F2 pistons. The F2's cam doesn't offer much more lift than a K6 cam, (about 1mm, from memory) so even a stock K6 cam would be pushing the valves awfully close to the F2 piston's crowns. Personally, I'd go the other way, I'd use stock K pistons with a better aftermarket cam. Cheers, Terry. ;D
Offline liPPy
  • 1978 cb750k
« Reply #219 on: December 14, 2011, 01:05:21 PM »
How would these pistons fare in a k8 head?
Not from a compression perspective, but would there be any valve interference?
« Reply #220 on: December 14, 2011, 02:48:58 PM »
They work fine in a K7/8: I have built 2 of them this year that way.
The K7/8 cam is like the F0/1 cam, about 0.5mm more lift than the older K cams, and 5 degrees retarded durations.
Offline fatmatt650
  • Part Deux
« Reply #221 on: December 14, 2011, 03:06:50 PM »
"Don't expect much out of just adding this 836 kit Matt, my gold K2 with F2 engine fitted with the "correct" Wiseco 836 kit didn't really feel any more powerful than my stock K0, so unless you're gonna get some headwork done, and a better cam (in which case you'd pony up the dough for a more appropriate big bore kit anyway) you're probably just wasting your time."
Like I said in the quote in your post, I am getting the head rebuilt. I plan to send it down to A.P.E. for the full o-haul they described in the 'Rebuilding f2/3 heads' post a couple days ago. Soooooo. While I'm in there I figured I'd bore it out a bit as well. As they say, "The only REplacement for DISplacement is positive manifold pressure" and I don't plan to add a turbo. In an earlier post I asked for suggestions on cams for this project but noone has been forthcoming w/ opinions yet. As this motor will probably never see redline and I don't wish to increase compression due to the increased head temps that come w/ it and the lack of availability of high octane gas in many areas these seemed to me like the most appropriate piston. I am still awaiting a definitive reply from HondaMan on combustion chamber volume. As I understand what he was saying (and I could be mis-understanding this) the actual static compression from the factory was in fact less than the stated 9.0:1 in the manual and the published numbers were based on delayed cam timing. -
"Part of the published compression ratio of the "F" engines is not from static compression, but from delayed cam timing (5 degrees later than K0-K6). ... The delayed cam adds a dynamic compression increase at engine speeds above where the incoming charge can force its way in against the exhaust pressures during overlap, which gives those later bikes that "rush" feeling at 6000+ RPM (that's about when the cam starts getting effective)." - HondaMan
Opinions aside, it will be interesting to see what the actual static compression ratio numbers are, both stock and with these pistons.
Mick tells me that you believe these pistons will come in at about 7:1 CR. If that's the case than I'm going piston shopping again and these will end up in my F1. Can you recommend a piston that will give me approx. 9:1 CR? How about a good cam for this motor?
« Reply #222 on: December 14, 2011, 10:37:15 PM »
Thanks Matt, and I don't want to be caught up in another theoretical argument about compression ratio's, but all I'll say is that the combustion chambers in an F2 engine are much bigger than a K or an F engine so that Honda could re-angle the valves to increase their size, so in turn they had to use a high dome piston to fill that big chamber, and the EBay K series pistons obviously won't give you anywhere the CR of the purpose built F2 big bore pistons from Cyclex etc.
I like the APE F2 heads, they appear to be good value for money. I haven't ever installed a hot cam in an F2 so I can't help you there, but I've always found the guys at APE and Cyclex to be very helpful with "real world" advice, as opposed to speculation, which you'll find plenty of here. Cheers, Terry. ;D
« Reply #223 on: December 14, 2011, 11:14:52 PM »
The 836 head gasket seems to work fine. The holes are cut for the K3 and later cylinders with the big oil seals, so if you use it in a K0-K2 cylinder setup, get some 12.5x2mm O-rings (8 of them) to fill in the holes and seal it a little better.
Offline Grnrngr
« Reply #224 on: December 15, 2011, 11:56:19 AM »
Thanks HM! This one's for my 74 K motor, but I'm prettty sure I'm going to do the 77 Auto motor as well. I'm sure that one would need a different gasket..
oh and Terry..that was a joke about the f pistons in the k motor...kinda figgered that's what would happen.   :D :D    thanks for the pics tho, always nice to have positive clarifiation of these things ya know.. :D
'77 CB750A
