Author Topic: Cheap 836 kits back on ebay...$110! *Update!  (Read 124068 times)
Offline bert96
  • past ride
Re: Cheap 836 kits back on ebay...$110! *Update!
« Reply #325 on: May 17, 2014, 03:12:36 AM »
I know the cylinder wall thickness is thin after an 836 kit,so i was wondering if it worth all the troubles and $$$ to replace the sleeves? .Cyclex sell thicker sleeves to solve this problem.
Bert
Envoyé de mon XT1034 en utilisant Tapatalk
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Online PeWe
« Reply #326 on: May 17, 2014, 04:35:19 AM »
No problem at all with the sleeves. Thicker sleeves if you want 915 kit that brings better rods.....
This eBay 836 kit is not high CR, no additional heat that need an oil cooler.
Offline bjbuchanan
« Reply #327 on: May 17, 2014, 11:24:59 PM »
You don't need thicker sleeves. That is why the 836 is so popular. It is the last step before you get radical
« Reply #328 on: May 17, 2014, 11:35:40 PM »
Well, technically you can go one more step and use CycleX's 849 kit, but that's another .5mm you need to take your sleeves out to, and they're already pretty thin with a 4mm overbore to 836cc. Cheers, Terry. ;D
Offline 01Thomas
« Reply #329 on: July 21, 2014, 12:37:07 PM »
This is just a quick note so that I can find this thread again in the future.
~T
Online PeWe
« Reply #330 on: August 05, 2014, 05:31:31 AM »
It is very temptating to order this 836 piston kit + some extra head gaskets + extra ring kits + clutch kit(s) early and later versions + cable kits + all other kind of CB750 stuff when its so cheap.
Then buy another CB750 to put the parts in.
I'm going to become a hoarder, right?
I hope they will sell 4-4 early CB750 OEM style for low price....
Offline MiGhost
  • What was that about being an
« Reply #331 on: August 17, 2014, 02:22:56 AM »
I am looking at this kit for the possibility of using in a 650 big bore engine. Yes, it will require resleeving.
If anybody could provide the missing specs for the pistons. I would greatly appreciate it.
Dimensions
•Lower piston diameter: 65 mm (2.55 inches)
•Centre of pin hole to crown:   mm (  inches) (compression height)
•Piston height:   mm (  inches) (overall height)
•Crown height:   mm (  inches) (dome height)
•Gudgeon pin hole: 15 mm (0.57 inches)
•Pin diameter: 15 mm (0.57 inches)
•Skirt height @ Pin:  mm (  inches) (exposed skirt)
•Crown to top ring groove:   mm (  inches)
•Bottom of skirt to bottom ring groove:   mm (  inches)
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline bert96
  • past ride
« Reply #332 on: November 19, 2014, 04:19:01 PM »
I have this kit and i was ready to bore my cylinders but the guy at the machine shop asked me if i wanted the medium grit or the fine grit for honing the cylinders...?
....so, fine or medium grit? is there any other things i should know before i go again to the machine shop?
thanks for your help guys.
Bert
« Reply #333 on: November 19, 2014, 06:43:46 PM »
Bert
Take your rings to him and let him see them. Cast iron rings use different grit from chrome (or moly) rings, etc. The angle of hone is also different, so they say.
Offline bert96
  • past ride
« Reply #334 on: November 20, 2014, 03:20:24 AM »
Which one is the best,220,280 325 grit  for our kit?
Bert
Offline bert96
  • past ride
« Reply #335 on: November 20, 2014, 03:10:07 PM »
Can't believe i have no answers...!?!?
There's a lot of guys here that got the same kit as me and nobody can share their expériences?
Come on guys!
Bert
« Reply #336 on: November 20, 2014, 03:17:45 PM »
Come on guys!
Bert
It may be your avatar Bert, mesmerizing... 8)
Offline bert96
  • past ride
« Reply #337 on: November 20, 2014, 03:18:34 PM »
Lol
Offline TurboD
« Reply #338 on: November 20, 2014, 04:14:36 PM »
Tell him 280, I have honed cylinders med to super fine. After a little run time the end result is all the same.  :)
« Reply #339 on: November 21, 2014, 07:02:59 PM »
Come on guys!
Bert
Oh, sorry, I was looking at a zipper...
Actually, I'm on the road, not getting reliable Internet at the motels. I stayed in one that didn't have working service last night. :(
Don't get too fine with the grit, unless the ring (top ring) is chrome. Then 320 is OK. Otherwise, use 2nn- something. The hatch angle is said to be 'important' when I've talked with ASME engineers before, but I think it is 'important' for them to argue amongst themselves about? No one had given me a definitive answer re: what angle is best at what grit for which ring type? As with most of the ME types I work with, they can answer any question with one or two variables, but having three seems to make them vibrate and lock in place. :D
They would HATE to try to program the machines they then build...they just make ME do that part. :o
Offline bert96
  • past ride
« Reply #340 on: November 21, 2014, 07:50:46 PM »
Thanks guys
Offline Garage_guy_chris
« Reply #341 on: January 12, 2015, 06:16:16 PM »
It would appear these may be coming back after being off ebay for a while...
http://www.ebay.com/itm/69-77-HONDA-CB750K-836cc-65mm-BIGBORE-PISTONS-KIT-W-HEAD-GASKET-CI-CB750KBB-/141538985630?pt=Motorcycles_Parts_Accessories&hash=item20f461869e&vxp=mtr
Also this thread has been sleeping a while any new reports / reviews on these? people running them? experiences?
I had a chance to weigh and measure a set of them up tonight and i was quite satisfied:
- 4 pistons within 2 grams of each other
- 4 pistons within 0.0002" of each other
« Last Edit: January 12, 2015, 10:38:04 PM by Garage_guy_chris »
« Reply #342 on: January 12, 2015, 07:01:05 PM »
 I haven't heard of any failures yet, they've been around a while. I don't have a lot of miles on mine but I have ran it hard.
Offline Nuffsa Fugginnuff
« Reply #343 on: January 12, 2015, 07:20:16 PM »
I'm 'in'.
Excellent info guys, especially since that's my intended project bike engine cc. As an aside, been trying to source a donor bike and/or motor here in Oz and abroad. Looking most likely to pick up a motor (and frame) from USA.
Alcohol & explosives, the key to a lasting relationship.
Offline koendd
« Reply #344 on: January 17, 2015, 11:42:55 AM »
to bad it's not a buy now item...
allready 153 $ now...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
« Reply #345 on: January 18, 2015, 08:38:23 PM »
I wouldnt worry i bet the guy is just feeling out the market.  he is probably looking to increase his prices a bit, notice the thread tittle is "$110" last kits were $120.   the next cheapest kit is the Cycle X  2nd (0.50) and 4th (1.0) Over Piston Kits @ $199.95 or for big bore, Cycle X 849 kit @ $249.95  i bet they come back at $130 or $140 this year
« Last Edit: January 18, 2015, 08:41:11 PM by Garage_guy_chris »
Offline la ca fe
« Reply #346 on: January 21, 2015, 11:44:30 AM »
Will this set fit a 78f motor?
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
Online PeWe
« Reply #347 on: January 21, 2015, 01:01:14 PM »
F2, F3 had higher piston domes, deeper combustion chambers in head. Compression will be lower with this piston kit. I think this is discussed earlier in this thread.
Offline koendd
« Reply #349 on: January 22, 2015, 06:30:39 AM »
not the same seller though? ships from US and different name.
still cheap though :)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
