hey guys have had a stiff throttle problem since ive owned the bike. its a k1 750 and i installed GSXR controls with the stock pull cable no push cable. the throttle snaps back really strong more that most later 750's ive riden but its twice as stiff to twist. ive lubed the carb rack has new cable and made sure its routed with very little bends and large ones going to the carbs. ive heard the early bikes tend to be stiff but mine kills my hand even riding for 5 min. need some help thought about going to a softer spring.
also what does the rubber around the return spring do?
thanks ryan
If by "twice as stiff to twist", you mean you changed the twist grip, and nothing else, and its twice as stiff to twist as it was with the original stock twist grip?
If so then you have inadvertently installed a quick throttle. I would suspect that the GSXR is certainly a quick throttle. That means it takes less of a turn of the grip to pull the throttles wide open. That also means you lose leverage and the effort will be increased proportionately.
Did you just change the twistgrip (and maybe the cable) but nothing else? Its the same spring as before?
PS: I prefer the quick throttle. So bulk up your arm.
PPS: the rubber on the spring is to keep it from vibrating I think, though I don't know why. Otherwise its like the rubber sheath on the centerstand spring, keeps it sheltered somewhat from the elements.
