Author Topic: What would you have done differently if....  (Read 4068 times)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: What would you have done differently if....
« Reply #25 on: April 23, 2006, 05:04:51 AM »
I like the narrow tires too, the big tires on a bike seem kind of goofy to me.  I would like to see more parts for our bikes.  Anyone know where we can get the original molds ;).
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
eldar
« Reply #26 on: April 23, 2006, 08:16:10 AM »
Well I do see the idea behind fatter ires and it is valid in racing applications. The more rubber you can put to the road, the faster you can corner and less spin on take off. You dont see dragsters running car tires do you? Nascar does not use a small little 165/14 tire. So while a rocket would benefit from a wide tire to maintain traction while going 200 around corners, a "chopper" has absolutly no use for them.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #27 on: April 23, 2006, 08:38:27 AM »
                          I don't like the huge hunk of rubber look either but, on the other hand I want a tire
            somewhat larger than factory.  Now the tires on that came on my CB450K7, CL450K6, CB500K
            and CB550K aren't too badly sized (even though I want a little wider) But, the tires that came
            on the 63' CB77 are smaller than I want (especially the rear one.) I mean, come on the rear tire
            on that bike looks like it should be on the front! I understand the beef about the monster tires
            but, after improving other features and warming up the motor, I'd want a little more rubber on
            the ground to go along with it.    Just my 2 cents worth. Later on, Bill
Member # 1969
Offline byidesign
« Reply #28 on: April 24, 2006, 11:53:53 AM »
 I figured I would ask this one,
    The earlier tensioners{one's with problems,
   Would It be that hard to retro/redesign one
    that really works.{if it will keep some of these machines on the road}
        If anyone had some {pic's} of some{and where damage occurs...
     that they could post, I would like to see.
          I havn't seen anything that couldn't be
      repaired/replaced yet, and some of the new
        materials are much,much better..
          {Toolmaker/designer},by trade.
              When in doulbt.go downstairs,..and...make it.
                    Hope it helps
                        Bruce
82CB650SC,80CM400
supersport_CB400F
« Reply #29 on: April 24, 2006, 12:03:25 PM »
I've fixed a couple with a needle file ;).....the chain grinds and locks the pivot solid   :o
« Last Edit: April 24, 2006, 12:16:58 PM by _biffta_ »
Offline JHansen
  • In a word... breathtaking
« Reply #30 on: April 24, 2006, 07:02:03 PM »
Biffta, that tensioner arm is nothing...
The arm I pulled out of my 400 was so chewed up, it completely opened up that boxed in part on the other (non pivot) side if the arm. What was once a 4 sided piece of metal was ground into 3. Also took some pretty good chunks out of the chain tunnel in my barrels.
'76 CB400f -cafe'd out
'75 CB400f -future project waiting in wings
'03 Yamaha V-Star Classic
'90 Honda VFR 750
supersport_CB400F
« Reply #31 on: April 25, 2006, 02:13:34 AM »
JH ouch that sounds like it was well worn, I’ve not seen one that bad but I’ve heard a couple of engines with some nasty noises coming out of them, so I guess they must have been in the same condition as yours. I can’t understand how people let them get that bad it’s only a day’s work to fix the problem.
Offline JHansen
« Reply #32 on: April 25, 2006, 05:40:24 AM »
That motor sounded like it had two dozen marbles rattling inside it. To top it off, the cam chain tension adjuster bolt had somehow snapped off and was seized up in the thread, also causing the spring loaded plunger to seize in its location. What a pain to put back to rights! Took some doing but got her done!!!
It was a nasty surprise for me as I purchased the bike not knowing this as I was primarily familiar with 550's (my first bike).
This is the ultimate lession in doing YOUR HOMEWORK!! before purchasing!
I knew the motor had issues, but I assumed it to be complete and not have bolts broken off, etc!
'90 Honda VFR 750
supersport_CB400F
« Reply #33 on: April 25, 2006, 06:11:19 AM »
JH, well at least you know about some of the issues that the 400 engine has now, even if it was a bugger to put right! It gives you a bike that’s just fun to ride, I think you’ll agree? I wouldn’t swap my 400 for one of those sandcast 750 things I’d rather ride a bike and enjoy it  8) ...... than polish it and wonder what its value is.  ;)
Offline JHansen
« Reply #34 on: April 25, 2006, 06:48:05 AM »
Amen to that-
'90 Honda VFR 750
Offline byidesign
« Reply #35 on: April 26, 2006, 08:20:35 AM »
Still a little reverse engineering, could keep a lot of bikes
 in good shape,and  on the road.
       Now I'm curious, I will have to find an old 400, just to
    experiment with it..
            Thanks
                Bruce
82CB650SC,80CM400
