Author Topic: Engine Finishes  (Read 1923 times)
36EL2212
Engine Finishes
« on: June 03, 2011, 06:34:50 AM »
I'm restoring my first Honda 750. It is a 1975 K model. Can someone please tell me what the factory finish on the head and cylinders is? Is it raw aluminum? How do I return them to original condition? Bead blasting? Soda blasting?
Any help would be appreciated.
Offline 76CB5WI
  • CHRIS
Re: Engine Finishes
« Reply #1 on: June 03, 2011, 08:05:51 AM »
Its paint
Bead will get you the best result.
Clean it out and well after wards. including the oil ways.
Get a good head gasket kit with all the orings..etc.
Finish with Duplicolor DE1615 and primer or VHT. :)
87 FJ1200
72 CB750
76 CB550
36EL2212
Re: Engine Finishes
« Reply #2 on: June 03, 2011, 10:56:50 AM »
Thank you, Chris. I just dropped off the parts to be soda blasted and picked up a couple cans of DE 1615.
I'll post some pictures when the project is complete.
charlevoix418
Re: Engine Finishes
« Reply #3 on: June 06, 2011, 09:24:26 AM »
Is Duplicolor DE1615 color very close from Honda original motor color?
Raynald
Offline SohRon
Re: Engine Finishes
« Reply #4 on: June 06, 2011, 04:45:10 PM »
DE1650 Cast Coat Aluminum is a little closer, IMHO. A semi-gloss that isn't quite as "silver" as their aluminum paint
« Last Edit: June 06, 2011, 04:46:49 PM by SohRon »
Offline Toxic
Re: Engine Finishes
« Reply #5 on: June 06, 2011, 04:56:32 PM »
That's a very pretty engine what does the rest of the bike look like?
Offline SohRon
Re: Engine Finishes
« Reply #6 on: June 06, 2011, 08:58:31 PM »
This is how the engine looks with the bike near completion (click on the pic for a larger view). Unfortunately, this is as far as this build got due to frame problems. I think the color is pretty close to original, without having to make special orders for the real deal.
« Last Edit: June 06, 2011, 09:12:12 PM by SohRon »
