Author Topic: Will the world explode if I use yamabond5?  (Read 2620 times)
Offline q2418130103p
« on: June 04, 2011, 06:30:38 AM »
So I don't know of any local places for hondabond etc, but I have plenty of yamabond5.  This is the black, drying type.  Not the semi drying type.
How terrible will that be when I go to split in the future?
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
Re: Will the world explode if I use yamabond5?
« Reply #1 on: June 04, 2011, 06:32:16 AM »
hell yeah it will. BOOOOM. (I have no idea, but I like the name of the thread)
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Offline Magpie
« Reply #2 on: June 04, 2011, 09:09:49 AM »
It didn't explode when I used Permatex Ultra Grey RTV Gasket Maker and it matches the engine colour so it hardly shows at all at the mating edges.
Cliff.
« Reply #3 on: June 04, 2011, 09:18:33 AM »
Well it will be more terrible than if you had used the semi drying type, which is preferred.  Autoparts will have the semi drying type.
Does the YB5 have silicone in it? That would be highly un recommended and your world may indeed explode.
Offline CycleRanger
  • No comment about being an
« Reply #4 on: June 04, 2011, 09:45:22 AM »
Permatex form-a-gasket #3 I think is what you need.  I think #3 is kind that never hardens.
The venerable Hondaman mentions it in his book, but I can't remember if he says 2B or 3.
Offline Kevin400F
« Reply #5 on: June 04, 2011, 10:24:10 AM »
The recommended product "Hondabond", is actually 3M Threebond 1104, same also as Yamabond 4.
Yamabond 5 is a different product and probably not the ideal choice in this situation due to its curing characteristics.
My fear is that it would start settting up too quickly, and potentially hold the cases apart slightly, increasing bearing clearance (which of course can lead to your world exploding).
Kevin
Offline nsargeant
  • Arguably the best bike ever!
« Reply #6 on: June 04, 2011, 11:34:39 AM »
just a thought but I think permatex avaition sealent never completely hardens either.  That is what is commonly used inbetween the cases on a VW type 1 engine.  Available at most auto stores.
Nathan
Offline mjstone
  • I'm definitly not a
« Reply #7 on: June 04, 2011, 02:14:35 PM »
No it will not explode, it will implode! :o
I believe it is permatex #2 that doesn't harden.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
« Reply #8 on: June 04, 2011, 04:20:12 PM »
I figured since internet answers are generally over dramatic, I formed my question to match.
I ended up finding some hondabond4 locally.
I played with the yamabond5, it is VERY hard to apply.  It is very stringy, dries very fast, and very difficult to spread.  And I believe it is a silicone based product.
Hondabond4 was so nice to work with, I applied it with an acid brush.
Thanks for the recomendations guys.
« Reply #9 on: June 04, 2011, 05:46:07 PM »
As an answer to the thread title...
Yes.  A more relevant question would be to ask when?
Offline jtb
  • An unlikely
« Reply #10 on: June 04, 2011, 07:20:19 PM »
Probably 2 days after the rapture. ;D ;D ;D
1977 CB750F
1985 V65 Sabre
« Reply #11 on: June 05, 2011, 03:26:26 AM »
Well good thing I didnt use it then
