Author Topic: Lube NOS throttle cables?  (Read 1387 times)
Offline david 750f
  • 1976 CB750F
« on: June 04, 2011, 01:06:47 PM »
Should one lube new Honda throttle cables?
If yes, what kind of lube? Graphite?
Thx
1976 CB 750F
Offline Bankerdanny
  • Endeavor to persevere
Re: Lube NOS throttle cables?
« Reply #1 on: June 04, 2011, 09:15:38 PM »
I wouldn't think that you would need to lube new cables, but I don't believe that it would hurt.
I invested in a proper cable lube system. They aren't that expensive and make the job MUCH easier.
  • I'm back
« Reply #2 on: June 04, 2011, 11:03:35 PM »
Genuine Honda cables are tefloncoated and do not need to be lubed. They don't like petroleumbased lubes. They do hurt.
« Last Edit: June 04, 2011, 11:05:09 PM by Deltarider »
« Reply #3 on: June 05, 2011, 12:46:36 AM »
If they are teflon coated a little silicon spray should be OK.....Also +1 on the cable lube thingy, they are excellent.....
Offline tommanos
  • 71 CB500
« Reply #4 on: June 05, 2011, 07:13:48 AM »
I used this EZ glider system on my cb500. Worked great with no need to remove or slacken the cables.
http://cgi.ebay.com/ebaymotors/EZ-Glider-Motorcycle-Cable-Lubricator-/270688295923?pt=Motorcycles_Parts_Accessories&hash=item3f06479bf3#ht_500wt_948
71 CB500
68 CL350
71 CL175
BMW R1100R
Offline Bankerdanny
« Reply #5 on: June 05, 2011, 07:32:30 AM »
Genuine Honda cables are teflon coated and do not need to be lubed. They don't like petroleum based lubes. They do hurt.
Yes, but his title says NOS, if that's the case they are unlikely to be Teflon coated. I would have to check my bottle, but I believe that my cable lube is not petroleum based.
