Author Topic: Highway RPMs  (Read 2704 times)
Offline longshanks
Highway RPMs
« on: June 05, 2011, 01:40:49 AM »
Hello gents,
I wanted to get a feel for what my fellow cb750 owners are taching out at cruising speed on the highway. I know it can vary from bike to bike depending on gearing, wheels, and sprocket set-up but with my K6 at 75mph I tach out at 5k rpm. What about everyone else?
cb450 K5
Offline dhall57
Re: Highway RPMs
« Reply #1 on: June 05, 2011, 01:51:42 AM »
I have a 750K6 also and run the factory set up 18/48 sprockets and at 70mph I'm taching 5 grand. Here's a pic at a little slower speed.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Bob Wessner
  • "Carbs Suck!"
Re: Highway RPMs
« Reply #2 on: June 05, 2011, 03:33:13 AM »
On my KO, with stock gearing, it runs 15 mph per 1,000 rpm. At 60 mph it is dead-on 4K.
Offline longshanks
Highway RPMs
« Reply #3 on: June 05, 2011, 09:55:03 AM »
Then yours is the same as mine. Is it okay to cruise at 5k for a long time? I assume yes because these bikes seem pretty rev happy.
cb450 K5
Offline mrbreeze
  • Not your average
Re: Highway RPMs
« Reply #4 on: June 05, 2011, 10:10:53 AM »
These bikes love hi R's. You could run all day at 5-6 K so long as you have good oil and a tuned engine. Mine runs 4K at 70mph (I dropped to a 42 tooth rear).
MEMBER # 257
Offline Gordon
  • 750K1, 550K2
Re: Highway RPMs
« Reply #5 on: June 05, 2011, 11:03:13 AM »
I just did over 600 miles at 6Krpm on my K1, and it ran like a top.  The red-line is way up there because these engines are meant to run fast.
Offline Pinhead
  • 1979 CB652-ST
Re: Highway RPMs
« Reply #6 on: June 05, 2011, 02:22:59 PM »
My '79 CB650 with a 17t front sprocket is 4k @ ~55 and 5k @ 70 (it's hard to say exactly because the speedo bounces around).
I'm considering installing a smaller rear sprocket to drop the revs by about 1k or so, as my rebuilt engine (11:1 652cc) has a ton more torque than stock.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline Bob Wessner
  • "Carbs Suck!"
Re: Highway RPMs
« Reply #7 on: June 05, 2011, 03:17:19 PM »
Should be no problem. I don't care for interstate riding much anymore, but back ... way back when I did, I rode it from Mich. to the tip of Long Island and then another trip to the Smokey Mtns. Much on interstates to get there. If you didn't do 70-75 mph on those, you would get run over.  ;)
Offline jtb
  • An unlikely
Re: Highway RPMs
« Reply #8 on: June 05, 2011, 05:03:15 PM »
I ran 6K all day long with GZ.  My speedo bounces too, but that is 85-90.  Crappy mileage at that rate.
1977 CB750F
1985 V65 Sabre
Offline Grabcon
Re: Highway RPMs
« Reply #9 on: June 05, 2011, 05:39:39 PM »
I have been using this sight to verify my speed and RPM as well. It is very interesting and allows the user to change up things to really see what happens.
http://www.gearingcommander.com/
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline JosepyK
Re: Highway RPMs
« Reply #10 on: June 06, 2011, 02:09:24 PM »
5K seems to be right around 70 for me with stock sprocket size on my F. But I'll add to the question, what kind of mileage are you getting?
« Last Edit: June 06, 2011, 03:26:58 PM by JosepyK »
'75 CB750F
'82 CB450SC
Offline grumpy
  • ..... '73 750K3 .....
Re: Highway RPMs
« Reply #11 on: June 06, 2011, 02:15:38 PM »
All stock 18/48, 5K at 70mph, 50mpg on flat interstate.
Offline mrbreeze
  • Not your average
Re: Highway RPMs
« Reply #12 on: June 07, 2011, 12:01:49 AM »
It all depends where you ride. If you do more flat freeway all day long...............do what I did.....(we are talkin' 750...right?).........drop some teeth on the rear sprocket. If you are good with town ridin' and moderate speed twisties....Keep the stock gearing. I sacrifice a little in town but when I do the slab all day....I'd rather be at 4K doing 70 than 5K.
MEMBER # 257
