Author Topic: Questions  (Read 8476 times)
prsman23@hotmail.c
Re: Questions
« Reply #50 on: July 17, 2006, 09:46:17 AM »
Big Shakespeare fan junkie?
TARKUS512
Re: Questions
« Reply #51 on: July 19, 2006, 04:44:08 AM »
And that's cool. Absolutely nothing wrong with that and anything else that floats your boat.
eldar
Re: Questions
« Reply #52 on: July 19, 2006, 07:21:14 AM »
But wasnt shakespeare an old english guy that never got laid in his time?
Offline cbjunkie
  • ...know what i'm sayin'?
Re: Questions
« Reply #53 on: July 19, 2006, 07:55:37 AM »
seriously?
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline cbjunkie
Re: Questions
« Reply #54 on: August 09, 2006, 11:54:23 AM »
The Ultimate Physics Exam
When asked to describe how to determine the height of a skyscraper with a barometer, one student replied: "You tie a long piece of string to the neck of the barometer, then lower the barometer from the roof of the skyscraper to the ground. The length of the string plus the length of the barometer will equal the height of the building."
This highly original answer so incensed the examiner that the student was failed. The student then appealed on the grounds that his answer was indisputably correct, and the University appointed an independent arbiter to decide the case. The arbiter judged that the answer was indeed correct, but did not display any noticeable knowledge of physics. To resolve the problem it was decided to call the student in and allow him six minutes in which to provide a verbal answer, which showed at least a minimal familiarity with the basic principles of physics.
For five minutes the student sat in silence, forehead creased in thought. The arbiter reminded him that time was running out, to which the student replied that he had several extremely relevant answers, but couldn't make up his mind which to use. On being advised to hurry up the student replied as follows:
    * "Firstly, you could take the barometer up to the roof of the skyscraper, drop it over the edge, and measure the time it takes to reach the ground. The height of the building can then be worked out from the formula H = 0.5g x t squared. But bad luck on the barometer."
    * "Or if the sun is shining you could measure the height of the barometer, then set it on end and measure the length of its shadow. Then you measure the length of the skyscraper's shadow, and thereafter it is a simple matter of proportional arithmetic to work out the height of the skyscraper."
    * "But if you wanted to be highly scientific about it, you could tie a short piece of string to the barometer and swing it like a pendulum, first at ground level and then on the roof of the skyscraper. The height is worked out by the difference in the gravitational restoring force T = 2 pi square root (l / g)."
    * "Or if the skyscraper has an outside emergency staircase, it would be easier to walk up it and mark off the height of the skyscraper in barometer lengths, then add them up."
    * "If you merely wanted to be boring and orthodox about it, of course, you could use the barometer to measure the air pressure on the roof of the skyscraper and on the ground, and convert the difference in millibars into feet to give the height of the building."
    * "But since we are constantly being exhorted to exercise independence of mind and apply scientific methods, undoubtedly the best way would be to knock on the janitor's door and say to him 'If you would like a nice new barometer, I will give you this one if you tell me the height of this skyscraper'."
Who was the student ?
« Last Edit: August 09, 2006, 01:44:59 PM by cbjunkie »
1971 750K1
the free men.
Offline dusterdude
Re: Questions
« Reply #55 on: August 09, 2006, 01:43:57 PM »
i don know ,but i like his/her thought processes.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: Questions
« Reply #56 on: August 09, 2006, 04:26:12 PM »
Sounds like something big "A,E" would say. ;D
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
