Hey all. I'm a newb working on my first bike. Last fall I bought a 76 F with pods and RC exhaust, Dyna S ignition, and I'm running NGK D8EA plugs. I perceive a lean condition based on what happens mid-throttle in 4th or 5th at highway speeds. I twist the throttle to say 50% and the bikes gets louder (sounds bogged down) but doesn't increase in RPM until a second or so later, and then it's a slow acceleration. the same happens on WOT, but less so if I twist slowly. I think it runs hot, but I can't give you a temp reading. I've done all the usual stuff: changed oil, set valve tappet clearances, adjusted the timing on the Dyna plate with a strobe, worked through all my electrical issues (holding a nice charge now), and rebuilt the brake masters and calipers. It runs well at startup, but this condition seems to get worse as the bike warms up (maybe overheating), and I would say that it ran better when the weather was in the 40's and 50's too, which indicates it's running rich, but I'm not sure.
Last fall, I dropped the bike off at a shop to have them clean the carbs and sync them, just to get to ol' girl running (it wasn't running when I bought it for a song). I know that you're supposed to do that last, but I wanted to know that the bike would run before I sank more money into it. Then I did all the maintenance I mentioned, so I'm kind of working backwards. The shop had bench synced the carbs and set the bleed screws to 1 2/3 turn out. I got higher RPM with them turned to about 2/3 out, so I have them set there. It starts easily and idles well at 1600.
These plug shots are with plugs that are at about 800 miles (not a WOT plug chop, just current condition). I was doing maintenance over this 800 miles, so I'm not sure if this reading really means much. I just adjusted the timing about 200 miles ago and that was the last thing I did. I have this sneaking suspicion that the PO put the pods on without rejetting. I do have the airbox, so I could try that. Let me know what you think about the setup or anything I've done and/or about the plug pics. Thanks!
