Author Topic: How easy is your bike to put onto center stand  (Read 6983 times)
Offline Scott
  • 72 CB750
« on: June 08, 2011, 04:03:26 AM »
I have a 1975 rickman using engine etc (center stand) from a 1971 CB750.
The bike is new to me and it is quite hard to put onto center stand.
Anyone know if the stands changed at all from 1971 to 1975.(might look for a later model stand)
The bike has new rear shocks and tyres pumped up and it is still a barstard to put onto stand
Thanks for any thoughts
Scott
Offline Scott S
Re: How easy is your bike to put onto center stand
« Reply #1 on: June 08, 2011, 05:26:27 AM »
 If it's been lowered at all, it can be a #$%*.
 Try putting a board under the centerstand for a little more leverage.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline cookindaddy
  • I sure love this bike!
« Reply #2 on: June 08, 2011, 05:36:37 AM »
There is of course a technique to this which makes it easier. Perhaps you know to first rock the bike slightly with your foot on the stand lever to feel that both feet of the stand are on the ground. With a firm grip on the back grab rail you then step hard on the stand lever while lifting the rail and the bike rocks up onto the stand fairly easily. Without both stand feet on the ground it is almost impossible to get the bike onto the stand.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline 76CB5WI
  • CHRIS
« Reply #3 on: June 08, 2011, 06:04:51 AM »
My fj1200 goes up easier than this K2 750..Im six four and 280 and its still a grunt to get the 750 up on
the stand....theyre just that way.
87 FJ1200
72 CB750
76 CB550
Offline Trav-i
  • Has finally become an
« Reply #4 on: June 08, 2011, 06:56:25 AM »
My 78 F3 is actually pretty easy to put on the center stand, once I figured out the technique.  And that is coming from someone who is 5'7" and 130 pounds.  Check out youtube there are some good videos on center stand technique.
Forum member #9962
1992 GL1500 Interstate
Offline wixil
  • gas passing
« Reply #5 on: June 08, 2011, 07:18:18 AM »
Technique is everything.  I struggled for quite a while with my getting my K6 on the centerstand, but after I watched a few youtube videos on the subject (mostly big BMWs) I got it the first try.   It's like cookindaddy says.  I rock the bike back with my left hand on the bars, push down hard with my right leg with the foot on the stand (making sure both feet of the stand are touching the ground) and pulling up with my right hand on the grab bar behind the seat.  It's kind of like when you were a kid trying to figure out the patting your head while rubbing your stomach thing.
Offline tlbranth
« Reply #6 on: June 08, 2011, 07:38:56 AM »
That would make it worse.
The leverage on my 750 isn't too good. It's a bit of a strain. I remember once on a trip in 1973 or 4, I pulled a back muscle really bad trying to get the thing on the center stand. Now I don't have the grab bar either. My Goldwing is a snap to do - much better leverage.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Coyote13
« Reply #7 on: June 08, 2011, 08:23:44 AM »
Easy.  Left hand in the center of the handlebars, right hand on the left peg, right foot on the center stand.  Upsy-daisy!
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline Frankenkit
  • Industrial Strength
« Reply #8 on: June 08, 2011, 08:26:54 AM »
My 350 is super easy.  The 650's been lowered, so I back it up on a couple boards to raise it, then centerstand it. Still a heavy pig, but manageable that way.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline excellrec
« Reply #9 on: June 08, 2011, 08:42:25 AM »
I only use the center stand on mine since the taller tires cause the side stand to lean it over too much for my comfort. With that said I can throw it on the center stand with one hand and my foot putting in about as much effort as it takes to open a car door.
bollingball
« Reply #10 on: June 08, 2011, 09:06:05 AM »
+1 tlbranth Put the board under the rear tire not the center stand. You should not need it unless something has been modded.
Offline jneuf
« Reply #11 on: June 08, 2011, 09:22:32 AM »
I struggled for awhile until I figured out the proper technique...I was attempting to pull the bike back onto the centre stand, as opposed to really pushing down on it and lifting with your right hand. Now that I figured that out, it's super easy....on my cb550 and cb400f anyways...my cb750 doesn't have a centre stand, so I haven't tried a heavier bike like that yet.
'75 CB400f
Offline DJ_AX
« Reply #12 on: June 08, 2011, 09:56:45 AM »
Yeah it's technique.
Like lifting something heavy... focus more on pushing with your leg muscles.
I hold the grab rail directly above (plumb) where the center stand first touches the ground to get the best leverage. No rolling or rocking. Just line everything up and press.  8) Works for me!
(to add: My avatar is before putting stock length shocks on and lowering just a smidgen...
on the center stand now my rear wheel is at least a few of inches off the ground.)
« Last Edit: June 08, 2011, 10:01:41 AM by DJ_AX »
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #13 on: June 08, 2011, 10:28:22 AM »
For me, it is technique. I got rid of the side stand on my '77 750k, and after using the center stand exclusively for more than a season, I can put it up without much effort at all.
Quote from: SOHC Digger, RIP
'77 CB750k
Offline Scott S
« Reply #14 on: June 08, 2011, 11:29:14 AM »
 Yes, that is what I meant to say.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott
  • 72 CB750
« Reply #15 on: June 08, 2011, 12:26:45 PM »
Thanks heaps for the replys
I'll work on technique before I go looking for a different stand.
The bike is a bare frame at the moment (pulled it down on the weekend)
But it means I can clean and paint my existing stand rather than look for a new one.
Scott
Offline gnarlycharlie4u
  • Far from being an
« Reply #16 on: June 08, 2011, 12:27:03 PM »
after getting a lowered GL1000 with 2 flat tires on the centerstand solo, putting these cb750's is a snap (i'm 150lbs.)
if it's hard then try putting the back wheel on a raised surface like a 2x4
edit: whelp it's been said already^^ but yea it's a good technique.
Offline c(b)hris
« Reply #17 on: June 08, 2011, 01:24:35 PM »
mine is extremely difficult.  i attribute it to the center stand being in a box somewhere in the garage.
75 CB550
74 CB750
  • Far from being an
« Reply #18 on: June 08, 2011, 02:23:07 PM »
hey for a while my center stand WAS a box in the garage.
Offline davesee
« Reply #19 on: June 08, 2011, 05:52:27 PM »
i used to get someone to help me until i saw this video. i did what this guy did and i laughed at how easy it was.
Centerstanding a Goldwing, rear
1980 honda cb650 with many weekends worth of modifications.
Offline jneuf
« Reply #20 on: June 08, 2011, 05:56:43 PM »
Ha! That's the same one I watched to help me!
'75 CB400f
Offline Gordon
  • 750K1, 550K2
« Reply #21 on: June 08, 2011, 05:58:40 PM »
If you have near-stock equivalent metric size tires it will be more difficult to get on the center stand.  The standard tires these bikes were designed to use have taller sidewalls which hold the bike about an inch higher off the ground.  I was amazed at how much easier it was to get my K1 on the center stand when I put on my first standard size tire.
« Reply #22 on: June 08, 2011, 06:55:55 PM »
My Seeley, with a K1 center stand, is also a pain. I suspect these frames may mount the motor and stand pivot lower??
Offline neverendingproject
  • Making the Northwest louder one road at a time
« Reply #23 on: June 08, 2011, 07:17:36 PM »
This thread is great! I had never gotten my CB500 or CB550 on the center stand alone without parking the rear wheel on blocks of wood until I saw this. Just went out there to nervously try it and it worked even with a flat front tire  8)  It's now even easier and safer than it was when I was using 3" of boards under the rear tire. Thanks guys!
'75 CB550 K1 Cafe Project
'72 CB500 Japanese market
Offline dodieninja
« Reply #24 on: June 08, 2011, 07:34:11 PM »
its super easy once you figure out the way to do it. i figured out how to on my friends bmw, and since then its been easy. except for when i got my bike in the shed, i left no room on that side so it was kinda hard.
In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.
    Douglas Adams
